LOF Glass Question - NCRS Discussion Boards
LOF Glass Question
  • Paul A.
    • April 21, 2021
    • 227
    LOF Glass Question
    Did Chevrolet use "LOF" glass from prior year on the next model year? My glass codes for my 66 are as follows:
    Windshield VJ, Shaded Soft Ray
    Pass vent VA, EZ Ray Eye
    Pass window NA, Soft Ray
    Drive vent YJ, Soft Ray
    Drive window YJ, Soft Ray
    Rear window VJ, Soft Ray
    As per the Corvette Spec Guide the month codes are Oct, Dec, Jan and the years all fit within my 66 model year. Car build date is 02/17/66.
  • Gary B.
    • February 1, 1997
    • 7078
    Re: LOF Glass Question
    Paul,
    Yes, the glass can be dated up to 1 year before your build date, but usually is much closer in time, like many of your pieces are. Obviously, your pass vent window with a VA code for Dec 1966 is not correct for your car.
    Gary
    • Frank D.
      • December 27, 2007
      • 2703
      Not to hijack but this is my May split window windshield labeling; clearly LOF but I suspect a service replacement (with the DOT labeling)- do the numbers tell me anything ?
      • David H.
        • June 30, 2001
        • 1567
        Paul
        "E-Z-EYE" & "FLOAT" are LOF Trademarks that indicate replacement (aftermarket) glass. As Gary has already pointed out, your passenger vent glass had a December 1966 date on your February 1966 car.
        "SOFT-RAY" & "FLO-LITE" are General Motors Trademarks. ("E-Z-EYE" & "FLOAT" were OEM on passenger cars, but NOT on Corvette)
        Dave
        • David H.
          • June 30, 2001
          • 1567
          Frank
          AS-1 is Clearest, laminated windshield glass.
          DOT 177 is DOT Code for L-N Safety Glass S.A. of Mexicali, Mexico (LOF's aftermarket glass facility).
          M61 is an internal LOF manufacturing code.
          "N J" indicates glass was manufactured in January 1965, or January 1978, or January 1991.
          Not sure of "DW636". (My 1980 also has this LOF replacement glass with a similar glass "bug", however, it shows "DW893".)
          Dave
          • Paul A.
            • April 21, 2021
            • 227
            Gary and David, Thanks for that info. I became suspect when I saw the EZ Eye Soft Ray title.
            • Larry E.
              • 1702
              FWIW:Here is my original LOF (Ottawa IL) Windshield in my 66 Base Engine Coupe. Larry
              Larry
              LT1 in a 1LE -- One of 134
              • Frank D.
                • December 27, 2007
                • 2703
                Thanks for the info!
                • John F.
                  • March 23, 2008
                  • 2424
                  I was born in Ottawa, IL. and lived about a half mile from the plant. My dad and a couple Uncles worked there at one time. I walked to kindergarten just a few blocks from the plant. The area the plant was in was called Naplate. We lived up against the quarry on Ottawa Ave. Brings back memories!
                  • Larry E.
                    • 1702
                    John:Yes memories for me also. Many People from where I live(20 Miles Away) worked at that plant. Those jobs where the
                    highest pay in the area. GM had an exclusive contract with LOF. ALL GM VEHICLES HAD THIS GLASS. ALL CORVETTES
                    IN THAT TIME FRAME HAD GLASS MADE IN OTTAWA IL.! Remember the story told to me that when GM gave the Blueprints
                    (Months before production of the car)for the 63 Split Window (Back Glass) the workers where trying to put together in their minds what the car would look like! Larry
                    Larry
                    • Paul A.
                      • April 21, 2021
                      • 227
                      Larry, So your windshield was manufactured August 65 I believe.
                      • Gary B.
                        • February 1, 1997
                        • 7078
                        • Harry S.
                          • July 31, 2002
                          • 5346
                          First Alpha Code
                          (Month of Manufacture)
                          Second Alpha Code
                          (Year of Manufacture)
                          • John F.
                            • March 23, 2008
                            • 2424
                            Larry, sent you an email.
                            John
                            • Larry E.
                              • 1702
                              Paul:Yes you are correct. Car's birthday date is 9/20/65; so you can see how close the dates where from when the
                              windshield was made and installed in the car. Picture below. Was very very lucky that the windshield survived all those years
                              w/o a rock chip or crack. Mileage from Ottawa Il to St.Louis was around 230 miles. Many trucks left Ottawa to St. Louis.
                              Larry
