'65 L-78 technical information search - NCRS Discussion Boards
    • 15706
    Prior to embarking on correcting the distributor installation on a '65 L-78 that I documented in another thread I dug out Vol. 8 No. 3 Corvette News that has an article on the new big block engine, including some basic tune-up data along with following comment.
    "Tune-up procedures are spelled out in detail in the 1965 1/2 Corvette Interim Shop Manual Supplement."
    Now I know that the 1965 Corvette Shop Manual Supplement has no information on the L-78 because it was published months before the 396 was introduced, but I have never seen this 1965 1/2 Corvette Interim Shop Manual Supplement.
    Does anyone know of this document and whether it is still available?
    • 43247
    Re: '65 L-78 technical information search
    Duke------
    It's a little beat up but I don't think this has the info you seek on the 396. The second one does, though:
    https://www.ebay.com/itm/333834016430?hash=item4dba0ed6ae:g:~f4AAOSwEV5f4k6 ~
    • Ray K.
      • July 31, 1985
      • 375
      Duke / Joe
      I have my original copy of the 1965 Chevrolet " Interim " Shop Manual. It contains information on all the 1965 396 engines both passenger car and Corvette, as well as details on the new Turbo Hydra-Matic transmission, plus the 3 speed fully Synchronized Transmission. A publication put out by Bill Thomas Race Cars in Anaheim, called the 396 Performance Handbook, was basically a reprint of the Chev Interim shop Manual featuring only the 396 engine section of the manual Thomas did add some of his own perspectives on engine building and tuning.
      Ray
        • 43247
        Originally posted by Ray Kimminau (8917)
        Duke / Joe
        Ray
        Ray------
        I agree. The Bill Thomas book is virtually a copy of the interim shop manual with his added info. The reason I suggested the versions shown above is because they usually sell for far less than the Bill Thomas book. Attached is a copy of my copy of the Bill Thomas book. I purchased this brand new about 50+ years ago.
          • 15706
          Thanks for the info, guys. I'll pass it along to the owner. It's interesting that the Corvette News article says 1965 1/2 Corvette Interim..." not Chevrolet, but I expect that was the result of the unconscious CN editors Corvette bias, and they actually meant Chevrolet.
          Roy - how many pages is the 396 section of that '65 1/2 Chevrolet Interim... manual. Short enough to photocopy, by chance?
          • Ray K.
            • July 31, 1985
            • 375
            Duke,
            The 396 engine mechanical section is 55 pages, with another 8 pages for Cooling and an additional 30 pages for Fuel and carburetors. There is also an Engine Tune-up section which is about 10 pages. In my opinion, the mechanical section and some of the tune up specs offer the most relevant information.
            Ray
              • 15706
              Thanks, that's too much to copy, but I'm sure the owner can find a copy to buy.
              • Scott P.
                • April 30, 1992
                • 178
                Duke, the manual also goes by ST-71. I have one I can mail you so you can see it and get out what info you want and then return to me.
                Fogaley@sbcglobal.net Scott
                  • 15706
                  Thanks, Scott. The owner is trying to find one to buy, but if he strikes out we'll take you up on your offer.
                  • William F.
                    • June 9, 2009
                    • 1364
                    initial advance: 10*
                    start 0*@1000
                    15*@ 1800
                    28*@4600
                    vacuum 0*@8 in
                    15*@15,5 in
                    Some of this especially vacuum advance sounds strange but comes for an old Corvette news article introducing the 425 hp 396.
                      • 15706
                      The VAC was poorly choosen, same 201 15 as on the '63 327/340, also a mistake, as I quickly found out had a significant idle stability problem. Typical L78/72/71 idle vacuum in neutral is 14" @ 900, so a 15.5" VAC doesn't pass the Two-Inch Rule. That's why I recommend the 12" B26 for SHP mechnanical lifter big blocks. It also works on L-36/68, typical idle behavior is 14" @ 900. A 8" B28 might be necessary with Powerglide since they pull less vacuum at the same idle speed in Drive.
                      • Randal M.
                        Infrequent User
                        • March 1, 1985
                        • 15
                        A new reprint is also available on Amazon: https://www.amazon.com/1965-Chevrole.../dp/B00BGBAXSG
                          • 15706
                          Thanks for the link!
