1964 front wheel cylinders bleed - NCRS Discussion Boards
  • Jack J.
    • July 31, 2000
    • 640
    Rears are done. Fronts look like a pain. Not much for easy access to bleeders even with a hoist. Any good suggestion for a one-person pressure bleed? Remove tires? Jack J.
  • Harry S.
    • July 31, 2002
    • 5333
    Re: 1964 front wheel cylinders bleed
    Yep, remove the wheels. If you trust the bleeders with the check-valve use those. Some tools I use. Made one.
    • Frank D.
      • December 27, 2007
      • 2703
      Literally - just did this job on my 63 yesterday, do remove the tire and you can turn the wheel for more visibility if needed. And a bleeder wrench as show above by Harry is a "must have" tool for the job.
      • Jack J.
        • July 31, 2000
        • 640
        A-HA! Thanks HARRY & Frank!
