Fuel Fitting? - NCRS Discussion Boards
Fuel Fitting?
  • Tom E.
    • June 1, 2019
    • 448
    Fuel Fitting?
  • Patrick B.
    • August 31, 1985
    • 2003
    • Tom E.
      • June 1, 2019
      • 448
      Re: Fuel Fitting?
      Originally posted by Patrick Boyd (9110)
      It looks like the setup for a 70-72 LT-1 and the similar Z28 Camaros. Don’t know if it was used on 66 L72.
      Patrick,
      Thanks for the reply, my google search also showed either the LT1 as you stated or possibly a L88? The distribution block may have been used on multiple applications. I believe its for a dual feed Holley.
      Tom
        • 15616
        Re: Fuel Fitting?
        Originally posted by Tom England (65936)
        Patrick,
        Tom
        The distribution block is, I believe LT1 only. The L88 had the fuel line support attached to the block, so the block is different for that application. The fuel line support is LT1 only. Together what you have is the rear portion of the fuel line for the LT1 Corvette and Camaro, as Patrick said. Not all Holley dual feed carburetors had the same fuel line configuration. For example Corvette LS6 had a different support, and the location and shape of the distribution block were different. See below for Corvette LS6 fuel line assembly:
        • Tom E.
          • June 1, 2019
          • 448
          Re: Fuel Fitting?
          Terry,
          Many thanks for the info and photo. I searched LT1 images some more and i believe you are correct, now to find someone who can use it!
          Tom
          • Mike E.
            • February 28, 1975
            • 5141
            Re: Fuel Fitting?
            Tom,
            Sent you a private message.
            Mike
