64 two top car showing NCRS - NCRS Discussion Boards
  • Michael D.
    Infrequent User
    • November 1, 1986
    • 25
    ON a two top car and you are showing with the convertible top only what bolt hold down set do you use, the ferrule with plug or hold down bolts installed
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 64 two top car showing NCRS
    On my 63 the bolts used to fill the hole with the convertible top in place are the same bolts used to hold the rear of the hard top in place.
    • Harry S.
      • July 31, 2002
      • 5342
      Ditto, That stops water from coming in when you are driving in the rain.
      • Kenneth B.
        • August 31, 1984
        • 2091
        FYI
        If you have a nice one & most are I think you would lose less points by showing with the hardtop on. Judges pick the repo soft tops to death. Make sure the soft top is there also.
