Auto Electric Service in North Florida - NCRS Discussion Boards
  • Scott S.
    • January 1, 2005
    • 30
    Hello everyone.
    Does anyone know of an auto electric repair shop in the Tallahassee/North Florida that can handle older (1960) Vettes. The Vette specialist in this area no longer works on cars and Im looking for a good electric service shop.
    Thanks!
    Scott Scearce
  • John W.
    Administrator
    • November 1, 1974
    • 5107
    Re: Auto Electric Service in North Florida
    Scott,
    The electric system on C1 Corvettes is so simple you shouldn't need a specialist to find or fix most issues. Tell us what you are having a problem with and someone here can probably tell you how to fix it yourself.
    Administrator
    www.ncrs.org
    • Scott S.
      • January 1, 2005
      • 30
      I have 2 issues. One is the dashboard lights have faded out as you go from right to left. And the main one is my left front and rear turn signals dont work any more.
      • John W.
        Administrator
        • November 1, 1974
        • 5107
        The headlight switch controls the dash lights brightness. There is a rheostat built into the switch. You can unplug and remove the switch. Next bend the tabs up and remove the cover. Spray some contact cleaner on the wire wound rheostat and the contact that sweeps across it. That may be all you need. If you have an ohm meter or friend that does connect it across the dash light contacts and see if the resistance changes by turning the switch knob back and forth.
        The turn signal lights are controlled by the contacts inside the steering column. Remove the steering wheel and check the contacts. See if any are broken. If not clean them well and watch how they work as you turn the wheel back and forth with the switch engaged. If they are broken you can purchase a replacement from about any vendor.
        Administrator
        www.ncrs.org
        • Scott S.
          • January 1, 2005
          • 30
          Thanks John.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17940
            John's suggestions are spot on.
            Your turn signals could be a ground problem if you don't find any problems in the steering column. You can test by clipping a ground wire from the negative battery terminal to the park and tail light bolts. If they light up, then you have a wiring harness ground problem to trace out.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Frank D.
              • December 27, 2007
              • 2703
              If your brake lights work on that side, its prob not a ground. Brakes and turn signals use the same filament in the bulb and the same ground.
              A quick check of the turn signals is to back up to a reflective surface and with the key on and foot on the brake jiggle the turn signal handle, if the lights start to blink the problem is in the switch (highly likely) and I have several good articles on fixing that issue. Do this check before tearing into the steering column. If you DO need to get into the turn signal switch, get yourself a set of "clutch head" screwdrivers first:
              https://www.amazon.com/CTA-Tools-875...0040587&sr=8-2
              ANOTHER THING to check is the two ivory plastic connector bundles under the steering column, make sure the wires are pushed TIGHLTY into the connectors on each side, I've had them come loose and screw things up (middle of picture to the left of steering column).
              As to the dash bulb fade, are you saying the bulbs get dimmer as you scan the gauges from left to right ?
              That would be odd as the power for all the "gray wire" dash lights comes from the same source, If that is the case perhaps a bulb (or two) has slipped out of its socket.
              Worst case, look up some members of the Florida NCRS in your area and see if they can get you a lead on some tech help.
              Yes, the C1 electricals are primitive but the average electrical tech is prob half the age of your car and a mechanical turn signal switch will probably put him in a catatonic state.
              • Scott S.
                • January 1, 2005
                • 30
                Thanks guys. Several good things to look at!
                Todays project.
                • Frank D.
                  • December 27, 2007
                  • 2703
                  The two connectors (if my poor eyesight is correct) are inside the red square and you can see they come straight off the the turn signal switch.
                  • Edward J.
                    • September 15, 2008
                    • 6957
                    • Scott S.
                      • January 1, 2005
                      • 30
                      Sure enough Ed. It was the front bulb. I noticed if the front bulb is dead the flasher module does not click for that side. Even if the rear bulb is not good the module will click if the front bulb is good. Thanks for that! Moving onto the dashboard light problem next.
