C1 Front End Setup Concern - NCRS Discussion Boards
  • Jerry M.
    • March 1, 1978
    • 147
    I'm concerned with how my '62 front end looks. At this point in reassembly, should the camber be this far off (-) centerline? At this point, I would almost expect the opposite condition.
    These are original spindles, a-arms and spindle shafts (except upper outer). New aluminum shim plates are installed correctly. King pins and pivot shaft bushings have been replaced.
    Does this look right at this point?
  • Jerry M.
    • March 1, 1978
    • 147
    Re: C1 Front End Setup Concern
    I forgot to mention that the springs are original and mounted with flat surfaces up and seated in the lower a-arm with the end at the hole.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17940
      Send Tom Parsons an email from the Members List pull down
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Jim L.
        • September 30, 1979
        • 1817
        You can't make a meaningful camber measurement with the suspension unloaded, which it appears to be.
        As far as the camber going negative at full droop, yep, it will do that.
        • Jerry M.
          • March 1, 1978
          • 147
          Thanks for the reply Jim. That's good news.
