C1 Underbody fiberglass cleaning / painting - NCRS Discussion Boards
  • Richard E.
    • 247
    I'm looking for suggestions to remove oil, grease, and possibly transmission fluid stains from the underbody fiberglass. Discoloration has penetrated the fiberglass over time, possibly the stains cannot be removed.
    Is there a method for cleaning the stained fiberglass surface sufficiently for paint without damaging the fiberglass? Are sealers available that would allow painting over these areas once cleaned?
    Also, did the factory prepare the C1 underbody pan or wheel wells with undercoat or paint?
    Thanks much for all responses.
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C1 Underbody fiberglass cleaning / painting
    there wasn't any paint applied to the underside of the c-1 floor pans from the toe pans rearward to the portion of the floor pan that lays directly below where the rear of the seats live. there should be some exterior color overspray on the spare tire tube's iuncerside. and perhaps some directly over the rear axle housing. if the c-1 isn't interested in ncos judging, then, since its your car, the entire floorpan underside can be painted. i'd simple clean and reclean the areas with petroleum stains with cheap lacquer thinner. good luck, mike mccagh
    • Daniel T.
      • July 5, 2019
      • 34
      https://youtu.be/etDMnV9epms. (No affiliation, it just looks neat!). Also have seen this used to remove household mold and smoke damage from wood.
      62 Corvette 327/340
      63 Corvette SWC 327/300
      67 Corvette Convertible L79
      2006 Corvette Z06
      2011 Corvette Grand Sport Convertible
      also a couple 68 Camaro's
      • Steven B.
        • June 30, 1982
        • 3990
        I spoke with a dry ice guy last week at the gas station (convenience store with gas pumps ) and he said he had done fiberglass boats, pine, metal, brick, etc. and it worked well. He had not done vinyl as in vinyl siding. I asked if he had done cars, specifically Corvettes and he had not.
        • Richard E.
          • 247
          Mike,
          Thanks much for the information. I'm actually asking for a friend that will be painting a C1 body soon. I do not know if judging the car is part of the plan, but I expect the body restoration is intended to be as factory correct as possible. I wonder if examples of typical factory overspray locations / pattern is documented anywhere? Thanks again.
          • Frank D.
            • December 27, 2007
            • 2703
            I use lacquer thinner and Tub'O'Towels and a scrapper where needed, finished my 63 last month (first pic) and my 61 had NOTHING on the glass under the chassis (second picture), I think any paint on an original car would look bad, really bad. On C2s IIRC there was some sort of undercoat in the fender wells to prevent rocks thrown from the tires hitting and cracking the fender underside, don't remember if my 61 had that.
            • Keith R.
              • August 31, 2001
              • 660
              I used lacquer thinner, lots of rags and I also soda blasted the wheel wells. It made them come out real clean. Too bad that I had to shoot undercoating on top of it though!
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              2013 427 Convertible
              Shade tree mechanic and
              B-52 pilot extraordinaire
