A165C Element - NCRS Discussion Boards
A165C Element
  • Jimmy G.
    • November 1, 1979
    • 977
    A165C Element
    Is anyone reproducing a correct debossed foam A165C element these days??
  • Harry S.
    • July 31, 2002
    • 5330
    Re: A165C Element
    Not that I know of. Since GM put a new set of rules in place about using their names/numbers/images many reproduction items went away.
      • 15706
      Re: A165C Element
      Does the FI air cleaner filter element have to be removed for judging? There is a modern cellulose conical filter from a Ford truck that is a near perfect fit for the '63-'65 FI air cleaner. I don't recall the part number, but it has been listed here more than once.
      Those foam filters won't catch much below the size of a hummingbird.
      • Jimmy G.
        • November 1, 1979
        • 977
        Re: A165C Element
        This is a Carb air filter element not FI. I do not think FI is removed. They were oil wetted to help catch stuff. But oil helps disintegrate the element Catch 22
        • Harry S.
          • July 31, 2002
          • 5330
          Re: A165C Element
          This is what they look like...
            • 15706
            Re: A165C Element
            OOPS! I confused the A165C with the A163C foam air filter that I recall is the '63-'65 FI foam air filter.
            A good cellulose replacement for the A165A is the NAPA 2070, which is a much more effective filter. I would only use the foam air filter for judging.
            When I rebuilt my SWC's 340 HP engine at 115K miles the only significant wear I found beyond mild valve guide wear was three thou taper on six cylinders and five thou on two, and I attribute that to the lousy foam air filter.
