Re: oil pan leak
Bruce,
Yes that repro timing chain cover is most likely the source of the leak. The lower flange is spot welded. The oil leaks between the welds in the spaces. Poor quality fabrication
Once removed, you could repair it. Use brake-clean on the flange to remove all traces of oil. Using a torch and silver-bronze rod, braze in the seams. You could also use silver solder. I've done that before with good results.
Unfortunately, another case of making repro parts work.
Keith, This may be your problem too even though yours may be original GM. The welds can separate over time. The worst part of all this is that darn front engine mount needs to come off to pull the timing cover on a C1.
Bruce,
