toe in for C2 with radials - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1364
    On previous posts some recommend 1/32" per side; some recommend 1/16" per side. Which is best for normal driving with P205/75-15 radials?
  • Leif A.
    • August 31, 1997
    • 3653
    Re: toe in for C2 with radials
    This has always been my "go to" chart...
    Leif
    • Mark F.
      • July 31, 1998
      • 1597
      Hi Leif,
      do you happen to have this chart as a separate pdf file that you could send me?
      thx,
      Mark
      • Frank D.
        • December 27, 2007
        • 2703
        I just used Leif's specs a couple of days ago to get my rebuilt 63 suspension dialed in and they work superbly..
        • Leif A.
          • August 31, 1997
          • 3653
          Originally posted by Mark Francis (30800)
          Hi Leif,
          Mark,
          I don't have this as a separate PDF file but you can right click on the image as save it to your documents. Hope this helps.
          Leif
          • Mark F.
            • July 31, 1998
            • 1597
            Hi Leif - yes that worked fine...thank you!
            thx,
            Mark
              • 15706
              Touring or Sport?
              • James W.
                • December 1, 1990
                • 2673
                Leif,
                Is this alignment done with a full tank of gas, or just the 2 or 3 gallons as described in the AIM?
                James
                • William F.
                  • June 9, 2009
                  • 1364
                  Thanks for info but have a question: Drawing for rear looks like it shows toe out rather than toe in. Which is it? thanks
                  • Leif A.
                    • August 31, 1997
                    • 3653
                    Originally posted by James West (18379)
                    Leif,
                    James
                    James,
                    I've never paid any attention to how much gas was in the tank when I had the rear aligned.
                    Leif
                    • Leif A.
                      • August 31, 1997
                      • 3653
                      William,
                      I have always looked at the picture as though the bottom of the picture was towards the front of the car and, therefore, the arrows indicate toe in.
                      Leif
                      • Mark G.
                        • January 31, 2007
                        • 177
                        The Hunter Hawkeye alignment machine I use, toe out is a negative number, toe in is a positive number.
                        • Frank D.
                          • December 27, 2007
                          • 2703
                          Touring or Sport?
                          Touring Duke, and set up for manual (not power) steering. I think my "guy" backed off the caster a tiny bit but I'd have to dig out my printout to be
                          sure. My 63 has nearly new tires, new manual brake drums on all four corners, 28 lbs in each tire and 1/2 tank of gas with a spare tire on board for the alignment, and a Van Steel rebuilt original steering box.
                          The car feels nimble and responsive now, without being "twitchy". Haven't had it up to interstate speeds yet as, after doing a fairly comprehensive suspension rebuild I find I have a bad rear U-joint (Ugh). So, while the driveshaft is out I'm having it balanced too. Then I'll get some high speed runs performed...
                          • William F.
                            • June 9, 2009
                            • 1364
                            Thanks, Leif.
