Maybe a solution on a rusted/frozen Clutch/Flywheel in Storage - NCRS Discussion Boards
  • Larry E.
    • 1695
    My old classic 1977 Chevy Pick-Up has been known to do the above when in extended storage. In researching
    this problem on this discussion board many solutions have been discussed. Patrick Boyd had a nice thread on
    this subject a little while ago. Could the following be done?>
    Before putting the vehicle in extended storage leave the clutch in the depressed (not engaged)position? You could
    do this by putting some type on metal handle/bar on the pedal. Does anybody see any problem with this? Could this do
    more harm then good?? Comments Please and Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Bill M.
    • 1328
    Re: Maybe a solution on a rusted/frozen Clutch/Flywheel in Storage
    Clever idea
    • Jimmy G.
      • November 1, 1979
      • 977
      Clutch springs could go bad rendering clutch usless
      • Jim L.
        • September 30, 1979
        • 1817
        Eeeeeyeah, I don't think I'd leave the clutch pedal depressed for an extended period of time.
        It's truly not a big deal to break the clutch loose if it freezes up. I've had to do it several times over the years.
