Driver door repairs C2 - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 218
    I am repairing/ replacing parts in my convertible. In spite of a good door fit the vent window front edge barely contacts the weatherstrip-nearly off it at the top. the weatherstrip is good, a replacement.
    I have had the vent window out to replace the front window channel run. It seems I have adjusted it as far as possible to move it inboard. Any other thoughts on what more to do to get the vent window better aligned?
    As a sidelight, I note a broken, now removed by me section at the top of the door which needs repair. Any suggestions on that? image is below
  • Tom E.
    • June 1, 2019
    • 448
    https://www.forums.ncrs.org/showthre...ght=Fiberglass
    Tom
    • John P.
      • August 31, 2002
      • 218
      Re: Driver door repairs C2
      Those are helpful threads . Thanks
      I am still curious whether there is any way to reset the vent window assembly so it tilts more inboard and gives a better fit at the windshield weatherstrip .
      It seems to just will not tilt any farther. Any other ideas?
      • Tom E.
        • June 1, 2019
        • 448
        John,
        The vent window assembly can be a bit tedious in getting properly aligned. I had some difficulty on one of mine, I keep working it and it it finally come into spec after about 1/2 hour of fiddling. Not sure what technical data you have but there is a very detailed procedure in the AIM for installing and adjustment of the vent window assembly.
        Tom
        • John P.
          • August 31, 2002
          • 218
