Replacing C4 Hood Release Handle - NCRS Discussion Boards
    • 43248
    All------
    Anyone ever replace a C4 hood release handle? There's a single screw retaining the handle assembly to the bracket. It's an absolute bear to get at. It will likely be even more difficult to re-install. Any words of wisdom?
    This assembly and handle must be one of the worst designed components of a C4. It should never have been made of plastic.
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Replacing C4 Hood Release Handle
    Joe,
    There are a lot of C4 parts designed "not for assembly"
    This video, or perhaps another that G will then suggest may help
    • Joe R.
      • July 31, 1976
      • 4551
      Joe,
      And they are in a remote location and not much access for an old man like me.
      Pulled this one off the shelf. If you need one let me know.
      JR
        • 43248
        Originally posted by Joe Ray (1011)
        Joe,
        JR
        [ATTACH=CONFIG]105367[/ATTACH]
        [ATTACH=CONFIG]105368[/ATTACH][ATTACH=CONFIG]105369[/ATTACH]
        JR------
        Thanks and thanks for the offer. However, I have several new GM handles in my stash. I won't have to use one, though. I did finally get the existing handle out. It turns out there was nothing wrong with the handle, itself. What had happened was that the drive pin that serves as the pivot shaft had partially worked its way out. There are no retainers for this pin which is an incredibly cheap and poor design. I've worked out a permanent fix for this and I'll be posting info on this soon.
