siezed piston - NCRS Discussion Boards
siezed piston
  • Daniel H.
    Infrequent User
    • February 12, 2020
    • 3
    siezed piston
    I can use some help.my 71 350 was outside under cover for many years without being started. I tried to turn it over by hand but it wouldn't budge. I tried filling the cylinders with marvel mystery oil,then tried deep creep, no luck. So I pulled the motor to find out what the problem was. The #2 piston is froze solid near the bottom of the cylinder.i can't remove the crank until. I get it out. I've soaked it in deep creep, then pbs blaster, tried hammering it out from the bottom with a piece of pipe.( I am putting new pistons and rods in after I can get it machined and probably bored out). I don't have an oxygen torch to heat it anymore and I doubt apropane torch will do much good.any ideas would be a great help, otherwise I'm going to have to take it to the machine shop and add to my cost. Its only a 270 hp motor, so its not real valuable.thanks
    • 43248
    Re: sized piston
    Originally posted by Daniel Horrigan (66831)
    I an use some help.my 71 350 was outside under cover for many years without being started. I tried to turn it over by hand but it wouldn't budge. I tried filling the cylinders with marvel mystery oil,then tried deep creep, no luck. So I pulled the motor to find out what the problem was. The #2 piston is froze so.id near the bottom of the cylinder.i can't remove the crank until. I get it out. I've soaked it in deep creep, then pbs blaster, tried ham ering it out from the bottom with a .eight of pipe.( I am putting new pistons and rods in after I can get it machined and probably bored out). I don't have an oxygen torch to heat it anymore and I doubt apropane torch will do much good.any ideas would be a great help, otherwise I'm going to have to take it to the machine shop and add to my cost. Its only a 270 hp motor, so its not real valuable.thanks
    Daniel------
    I've had this experience with a short block that I stored for many years. It was almost impossible to remove the pistons. So, I sent it out to the machine shop since it was going to need machine work anyway. The shop told me that they had to break apart the pistons in the bores to get them out using chisels and sledge hammers.
    • Domenic T.
      • January 29, 2010
      • 2452
      Re: sized piston
      Daniel,
      When I worked as a mechanic a fellow brought a 66 Chevelle in with a 396 he rebuilt. Car was towed in and story was that the engine would not start and sat for over a year.
      It had what is called indifference in metals and some pistons welded to the cylinders. It had a white powder like substance. I talked to a lab guy and he said that most likely this can happen when engines don't start and gas is left in the cylinders. He said that raw gas and oil will turn to some kind of acid.
      Dom
      • Daniel H.
        Infrequent User
        • February 12, 2020
        • 3
        Re: sized piston
        Thank you John for the advice. I guess I will just take it to the machine shop and let them handle it.
          • 43248
          Re: sized piston
          Daniel-------
          ...if you can find a machine shop that's willing to take it on.
          • Bill M.
            • 1328
            • John R.
              • November 1, 2005
              • 433
              Re: siezed piston
              Had the same situation. Let PB blaster sit for days, weeks and still could not move it out. Then tried a heat gun where I let it heat up and cool down while applying PB blaster and that did it. Used a hammer an rod to push it out.
