Name that pipe. Engine and Year - NCRS Discussion Boards
  • Steve F.
    • December 9, 2020
    • 38
    We believe its a BB 66-67
  • James G.
    • August 22, 2018
    • 801
    Re: Name that pipe. Engine and Year
    If you lay them out like on a car -on the SB set the vertical pipe going up to the manifolds will be straight up and down,
    If you lay big block pipes out like they are on the car - the pipe going to the manifold will be angled toward the front of the car.
    I think they are 2.5" -65-67 Big block?
    James A Groome
    1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
    1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
    My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
    Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
    • Larry M.
      • January 1, 1992
      • 2701
      What is the head pipe diameter?? That will also narrow it down.
      Larry
      • Jimmy G.
        • November 1, 1979
        • 977
        Big Block 65 - 66 - 67
        • Jaime G.
          • April 1, 1988
          • 480
          I agree with Jimmy, 65,66,67 BB.
          • Steve F.
            • December 9, 2020
            • 38
            Yeah its a 2.5 pipe. Looking for a SB pipe. We found this one and were hoping.....
            • James G.
              • August 22, 2018
              • 801
              I had assumed a 65 365 or 375 with side pipes could be a 2.5" system so in that case it would be easiest to determine if laid out on the ground. - if they point vertical without an angle toward the front of the car they are small block.
              Am I mistaken that a 65 L76 or L84 with N14 would have 2.5"?
              James A Groome
