early 1969 L-46 pulleys Question - NCRS Discussion Boards
  • Daniel T.
    • June 30, 2018
    • 48
    Gentlemen, My car started life with an L46 option. It also came with options N40 power steering and C60 A/C. The pulleys on the crank and water pump appear to be configured correctly, however they do not appear to be deep groove pulleys. My question is, did the 69 L-46 with A/C and power steering options use the deep groove pulleys. Thanks for any help here I've seen alot of discussion on this but no definite answer to this question.
    • 43273
    Re: early 1969 L-46 pulleys Question
    Daniel------
    1969 L-46 with N-40 and C-60 did not use deep groove pulleys.
    • Daniel T.
      • June 30, 2018
      • 48
      Joe, Thank you very much for answering a long pondered question for me. This was my suspicion all along. Also thank you for being clear and concise. You Sir, have made my day. thanks again.
        • 43273
        Daniel------
        GM #3850838-----2 groove crankshaft pulley (may also have been GM #3876846)
        GM #3751232-----1 groove crankshaft add-on pulley (power steering pump driver)
        GM #3890419-----2 groove waterpump pulley (may also have been GM #3911013)
        GM #3883235-----1 groove waterpump add-on pulley (AIR pump driver)
        GM #3917234-----AIR pump pulley
        GM #1949356-----Alternator pulley
        GM #3770509-----power steering pump pulley
        All the above are standard groove pulleys
