gas tank sending unit o ring - NCRS Discussion Boards
  • Mel S.
    • August 31, 1992
    • 264
    I installed a new O ring in my gas tank for my sending unit for my gas gauge in my 66 conv. All was well for about 3 months. Then it started to "leak" gas. I took it out, cleaned all surfaces, let dry and applied a small amount of black oil resistant silicone on all surfaces. Reinstalled all and good to go. Now, about a month later, it is leaking again. I purchased a new O ring but wanted some input before I "tried" another install
    Mel
  • Harry S.
    • July 31, 2002
    • 5338
    Re: gas tank sending unit o ring
    Mel, the reproduction O-rings are not as thick as the originals, so they start to leak quickly. Originals are available often on eBay.
    • Dan B.
      • July 13, 2011
      • 545
      Also, the O ring should be soaked in oil prior to install which will cause it to swell slightly and fit tighter. No other sealer is needed.
      • Mel S.
        • August 31, 1992
        • 264
        Thank you very much
        Mel
        • Larry M.
          • January 1, 1992
          • 2701
          The GM Part # for the o-ring is #3825206. None (NOS) on Ebay currently. Be advised that GM has reissued this o-ring gasket, but that newer part is currently back ordered. The GM re-issue may be the ticket for getting a good one.....if you cannot find NOS. NOS have a "JR". logo on the o-ring tab.
          Also consider installing a new GM locking ring for the gasket. Part # 3774937. These are readily available on Ebay.
          Larry
          • Tim T.
            • December 9, 2009
            • 141
            Dr Rebuild has NOS ones but I believe he is still closed.
            Tim
            • Richard G.
              • July 31, 1984
              • 1718
              I had to use the original lock ring on my reproduction tank. I couldn't tell the difference visually.
              The original was much harder to turn and lock in place.
              Might give that a try if it's an option.
              Rick
                • 43263
                Larry
                Larry------
                I'm not surprised the lock ring is readily available on eBay as they're still available from GM.
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Tim
                  I believe that to be the case, but Lord forbid that I say so.....
                  There is a significant thinckness difference between the repro and original/NOS O rings as shown.
                  • Bob W.
                    • December 1, 1977
                    • 802
                    Frank, This is bad when they cant repo a rubber o ring correct.
                    Bob
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      Bob
                      Look - there are a ton of parts like that unfortunately.....rear leaf spring rubber cushions, a simple glove box light socket, etc..
                      You would think with laser scanning, CAD/CAM and 3D printing the reproduced items would be as good or better than the original stuff.
                      [/rant]
                      • Bob W.
                        • December 1, 1977
                        • 802
                        Frank, Maybe if the vendors would stop buying and selling this crap things would change. But I guess it all comes down to $$$$.
                        Bob
                        • Mel S.
                          • August 31, 1992
                          • 264
                          Thanks again to all for the help
                          Mel
