t3 headlights - NCRS Discussion Boards
t3 headlights
  • Keith G.
    • October 31, 2006
    • 316
    t3 headlights
    For1967 which way should the lines run ???
  • Arland D.
    Moderator
    • July 31, 1980
    • 430
    Re: t3 headlights
    I believe there are no lines in the triangle and no DOT. The word GUIDE should be present.
    • Frank D.
      • December 27, 2007
      • 2703
      Re: t3 headlights
      I've had this document for a long time but never reallly verifired all of it,
      • Brian M.
        • February 1, 1997
        • 1842
        Re: t3 headlights
        If you are having your car judged, I wouldn't take a chance with Original T3's they go Puff too often, Repop's are reliable and a small standard deduct. JMHO
        • Frank D.
          • December 27, 2007
          • 2703
          Re: t3 headlights
          I ran originals through regional judging, but I had long ago sealed up the electrodes on the back along their base with hi-temp RTV to prevent them "sucking air" - seems to have worked.
          • Jaime G.
            • April 1, 1988
            • 480
            Re: t3 headlights
            I have Duntov'd 6 cars with original T-3 headlights with no problem at any level. Be choosy and check them.
            • Sal C.
              • December 1, 1984
              • 430
              Re: t3 headlights
              As Jaime stated. All the cars that I have had certified have had OE lamps. If they don't "go Poof" the first time you test them they'll probably last forever.
              • Sal C.
                • December 1, 1984
                • 430
                Re: t3 headlights
                P.S. I have never had any luck with sealing the terminals (NOS or otherwise). I think if they were leakers before the sealing attempt, there's probably enough air in them already for a smoke show.
