pushrod question - NCRS Discussion Boards
pushrod question
  • Mark H.
    • July 31, 1998
    • 384
    pushrod question
    I am getting ready to clean and install the pushrods and rockers on my '64 L75. I am reusing pushrods from a prior rebuild - they barely have any miles on them. I numbered them so I know where they go, but did not label the top and bottom. How critical is this? Each pushrod has an end that is very clean, and an end that is noticeably dirtier. Is there a rule of thumb that the dirtier end is usually on the rocker or lifter? Thanks.
  • E B.
    • March 1, 1978
    • 126
    Re: pushrod question
    Rub marks through the heads on push rods would indicate up position
    • Mark E.
      • April 1, 1993
      • 4607
      They can be installed either way.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • David M.
        • September 30, 2004
        • 533
        Roll each one on a flat surface to check for any deflection.
        • Jimmy G.
          • November 1, 1979
          • 977
          They are so cheap, I would consider using new units.
          • Bill M.
            • April 1, 1977
            • 1386
            Your pushrods may have a hardened tip. That tip goes to the rocker arm.
