Bucket opening on C2 passenger side appears to be bigger than driver side - NCRS Discussion Boards
  • Larry E.
    • 1677
    I have seen many C2 pictures on the internet and a good portion shows the bucket opening on the Passenger
    Side slightly bigger than the Drives Side. Has anybody else noticed this? See the gaps Below. If so why would this be? They all can't have a repro front end on.
    Thanks in advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: Bucket opening on C2 passenger side appears to be bigger than driver side
    My buckets are pretty uniform...... My body was made in St Louis. Maybe that is the difference... I know, the hood stripe is not quite correct.......
    • Larry E.
      • 1677
      Stephen>Yours look good and consistent. I would say of all my pictures the percent of C2 that have a bucket width difference
      from side to side is around 35%. Maybe they produced a batch with a little difference in the tolerance from time to time. Another one of
      my pictures below. It is odd that I never see a bigger width difference with the Driver Side being bigger. Comments?
      Larry
      Larry
      • Ronald L.
        • October 18, 2009
        • 3248
        Remember that there were two body shops building the bodies - compare AOS to AOS, St Louis to St louis, what do you see?
          • 6941
          Larry, could it just be that all the sanding and painting over the years. Are the headlight doors measurements same? Or is it the openings?
          • Larry E.
            • 1677
            Edward>I believe it is in the openings. I have measured mine and have email some owners and all claim the buckets themselves are pretty consistent with the width. Could not be the sanding and painting because you would then see some
            inconsistencies in the Drivers Side openings which I have never seen. Wonder what the opinions from the Judges and the
            the people who made up the new judging manuals would say? It seems that the peak of the inconsistencies came about in
            the 1966 year of production of the C2's. Larry P.S. My bucket openings are different by about 1/8" from side to side with
            the passenger side being bigger. Car has never been in an accident. In some cases the differences still could pass the tolerance test of .06 but still can be seen by the human eye. See Below
            Larry
