Adhesive used for C1 vinyl top installation? - NCRS Discussion Boards
  • Jill J.
    • October 30, 2013
    • 241
    Hi there.
    Is there a specific brand / type of adhesive that needs to be used when installing the pads, etc on a C1 vinyl top?
    I read through the posts Rich Mozzetta put up on the site and also have the Al Knoch video.
    When viewing the Al Knock video, they use a glue gun during the adhesive portion, which I purchased before seeing Rich's posts. Do you know what adhesive should be used in the glue gun? Not sure if it's a specific type / brand?
    Thanks for your help.
    Jill, 59140
  • Mike M.
    • May 31, 1974
    • 8385
    Re: Adhesive used for C1 vinyl top installation?
    I have one of al knock's glue guns and I use contact cement from Home Depot.. clean it thoroughly after use. mike mccagh
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Jill, Mike uses what I use........
      Weldwood Contact Cement.
      Rich
      • Mike M.
        • May 31, 1974
        • 8385
        rich is correct. weldwood is readily available, cheap, lasts me years(a 8 oz can) and is way stronger than the 3-M critters. mike
