My 70 LT1 had an after market rear spring, band clamps, painted liners, Etc.. My friend was doing a resto mod on a '71 and replaced his spring, which had worked well for years, with a custom setup. I checked it out and it appeared original, had the GMU stamp on the bottom leaf, so decided to use it to replace mine. Restored it, installed and made sure it had a load before tightening of all bolts. Not a fun project, but slow and easy and looks great, except higher on one side than the other. Adjusted the outer bolts slightly to get the back fender well 28-3/4" on one side and 28-1/2" on the other. Bolts have 3 threads remaining one one side and 5 on the other.
After driving it some the 2nd leaf from the bottom moved about 1/2" forward from the bottom leaf on the drivers side and of course the opposite on the right side. I released as much tension as possible without completely taking out, used blocks and clamps and pulled back together. After driving it some it has move right back out of alignment and even a little more.
I'm ready to take it all out and do over, but would appreciate any suggestions on what I may be doing wrong as I don't want to do this 3 times. I did replace the bushings and installed new shocks at the same time. I checked and the ears on the differential and they are not cracked that I can see. Thoughts appreciated .
