62 Over heating - NCRS Discussion Boards
62 Over heating
  • Roger B.
    • June 30, 1991
    • 82
    62 Over heating
    Installed a rebuilt 3269 carb on a 300hp
    Engine now goes to 220
    new items: carb,fan,water pump, electric fan.
    Any suggestions would be appreciated.
    thanks
    • 6956
    Re: 62 Over heating
    How old is the Radiator? Blockage? Anti freeze that does not get changed regularly will cause corrosion and causes blockage.Are you running a 180 thermostat? What temp do the electric fans come on.
    • Terry D.
      • May 31, 1987
      • 2697
      Re: 62 Over heating
      Wondering why you need an electric fan on a 300hp motor. If the fan is centered in the shroud, half in half out and you have no blockage you should not need an electric fan. Does it go to 220 all the time or just in slow traffic? Did you change the timing? Where did you get the water pump? Have you checked the temp with an IR gun?
      • Roger B.
        • June 30, 1991
        • 82
        Re: 62 Over heating
        In an attempt to correct overheating elec fan tried no improvement
        temp goes to 220 in three minutes
        timing checked
        today found (gas fumes in expansion tank)
        doing compression check next
        • Roger B.
          • June 30, 1991
          • 82
          Re: 62 Over heating
          Just been advised exhaust fumes in antifreeze
          does this mean
          1 head gasket
          2 head cracked
          3 block cracked?....
          • Joseph L.
            • July 26, 2012
            • 162
            Re: 62 Over heating
            I had a head gasket leak that appeared to occur only when running the engine at higher RPM (>3700). The temperature would rise above 210 and there would be coolant pushed out the radiator cap and all over the engine. The cap worked correctly.
            There is a test fluid and tester that sits in the radiator opening. If there is exhaust gas in the radiator, the fluid changes color. Testing my car had the fluid change color. I had the heads milled 0.005". The high temperature does not appear and there is no coolant covering the engine.
              • 6956
