Horn Remove/Replacel For A C2 (1966) - NCRS Discussion Boards
  • Larry E.
    • 1696
    Won't be too long before Spring is here in the MidWest. Planning my game plan for my 66 Coupe(Non-AC) project. Will
    remove/replace my horns. This can be done from the top w/o removing the hood correct? Will hood have to
    be decoupled from the hood support and pushed back for more clearance? My car is stored now in a bag
    so I can not look at it to determine how much room I got for sure. Anything I should be aware of on this project? Thanks in advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Horn Remove/Replacel For A C2 (1966)
    You will have to open the hood and fit your arms in the opening between the raised hood and the front valance. You should install a pin in the hood support to prevent the hood from accident closing on your arms.
    • Enzo C.
      • January 12, 2012
      • 536
      Acces with the hood open is pretty good.. make sure you protect the hood and upper valance in case something slips ... some nice fluorescent lights is definitely a must also...
      Enzo Colosimo
      Ncrs Ontario Chapter Chairman 🇨🇦
      ENZ-Z06/67
      • Keith B.
        • September 15, 2014
        • 1604
        if you have a friend you can trust as your removing them and bringing them up between the hood and front have your friend hold the hood up past the detent in the support.
        • Larry E.
          • 1696
          Update on this subject. Removed my repro's(Plastic Horns) today and installed my originals that where restored by
          Gary from "The Horn Works" in Beloit WI. Did nice job on them and went in w/o any problems. Did have sufficient room
          when hood is raised and pin put in the hood support. Tested and worked good. Quite a difference in the horn sound from
          the plastic repro's as one would suspect. Thanks-Larry P.S. Not sure how judges would be able to see the dates on the
          #'s> 487/488 horns unless they have some type of fancy mirrors.
          Larry
          • John F.
            • March 23, 2008
            • 2418
            Make sure they are oriented per the AIM.
