Temperature Sender Correct setup - NCRS Discussion Boards
  • James D.
    • March 9, 2021
    • 3
    1961, 245hp, dual quads
    For the temperature sender connection on the front of the manifold, does anyone have a photo of what the correct wire and connector should look like?
  • Carl R.
    • October 31, 2018
    • 64
    Re: Temperature Sender Correct setup
    This is a picture I took at Carlisle a few years ago. If you look closely you will see the wire is a dark blue, the connection is a slide on type connection. The top of the sending unit has what I will call a button head, this is where the wire connector slips on.DSCN0319.jpg
