Upper radiator bracket to the core support - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7078
    In reviewing the hardware to attach the upper radiator bracket to the core support, I found a spacer plate that does not appear on AIM UPC 11-13, A5, where I would expect to see it. The spacer plate is 3 5/8” wide, x 1” tall x 0.25” thick, and has the stamping “6 1 2”, which looks curiously like a June 12 date code, which would be reasonable for my July build date car. Has anyone seen such a spacer plate before? If so, why does it not appear in the AIM?
    Or is this plate likely an addition made by a previous owner for some reason?
    PS The radiator I removed from my ‘66 L79 was a correct GM one, but had a 1973 date code, so replaced for some reason by GM seven years from when the car was new.
    Gary
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Upper radiator bracket to the core support
    Gary,
    Was the car hit in the front end?
    Repaired in a mostly undectectable manner?
    Would not be normal for a fan shroud to be replaced unless there were 'external events', they generally last as long and the other fiberglass.
    • Gary B.
      • February 1, 1997
      • 7078
