67 oil filter housing - NCRS Discussion Boards
  • Enzo C.
    • January 12, 2012
    • 534
    I have to replace the copper gasket on my original oil filter housing
    Need some help on procedure and tools and who has correct gasket
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Larry M.
    • January 1, 1992
    • 2701
    Re: 67 oil filter housing
    Enzo:
    At one time LICS sold a rebuild kit with simple instructions. They probably still do.
    I believe Paragon still restores the oil can and internals.......if that is necessary. Generally during a full restoration, the long center bolt stem that holds the can to the block has a machined groove cut into it at the correct height, and a small (removable) c-clip is then used to hold the internals and spring etc all together.
    Larry
    • Danny P.
      • June 30, 2002
      • 344
      Enzo , try Zip's part number OP-173 it has all the proper seal and proper copper gasket you need, plus it come with installer tube for the c-clip lock works great no leaks op-173.jpgoil_canister_bolt_assy_75e0574f620d36c17584084ad01d8b48c4e4cac6.jpg48058743d1485783935-oil-filter-canister-rebuild-kit-oil_canister_kit.jpg
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        I've used several of those and work fine. IIRC LIC is their supplier. Just a bit pricey for such a small bag of parts. The install tube makes the bag bigger so you don't feel so ripped off. lol
        Rich
        • Enzo C.
          • January 12, 2012
          • 534
          Hi Danny
          I ordered one up today ... thanks
          Enzo Colosimo
          ENZ-Z06/67
          • Jeff S.
            • July 31, 1984
            • 384
            Ed
            NAPA sells the copper crush washer -- UP 1245. (I replace mine annually with oil & filter change). While you are there, grab some 1243's to stash away for next brake hose change/sealing.
            Jeff
