1963 SWC strut rods - NCRS Discussion Boards
1963 SWC strut rods
  • Richard L.
    • November 1, 1984
    • 194
    1963 SWC strut rods
    The original rear suspension strut rods on my 63 coupe are bent (to facilitate adjustment I'd guess by prior Bubba), rusty and ugly. I want to replace them with aftermarket tubular steel threaded adjustable ones instead of the factory stock cam bolt system. Any downside to this switch other than its incorrect originality? Ecklers, Corvette Central, or any other supplier recommended?
    Thanks all for your advice.
    Ric
  • Jim L.
    • September 30, 1979
    • 1808
    Re: 1963 SWC strut rods
    The rubber bushed originals allow for more compliance than any of the aftermarket struts. You might notice some increase in ride harshness with struts which do NOT have rubber bushings.
    As to choice of struts, get struts with Heim joints instead of poly bushings. And, as to choice of Heims, there are greasable and non-greasable. Get non-greasable which are Teflon lined. These will last the longest.
      • 6942
      Rick, I prefer the rubber strut rods, stay away from anything with the poly bushing strut rods. Get yourself some new camber bolts if others are rusted. Most of the venders selll reproductions of the original strut rods and camber bolts.
      • Richard L.
        • November 1, 1984
        • 194
        Jim,
        I'm ready to rock 'n roll with your best suggestion (non-greasable heim joints) but so far I haven't been able to find any listed with the usual vendors. Can you recommend one that has them available and whose quality you trust?
        • Jim L.
          • 1808
          FK Bearings makes good quality Heims. Here is an example which may or may not be the size you need:
          https://www.mooreparts.com/teflon-lined-chromoly-heim-joint-3-4-hole-x-3-4-16-rht/
          Also Aurora Bearings are very good but I'm having trouble posting a link to a site which carries them.
          • Jim L.
            • 1808
            Trying again:
            AB3/AM3Ball Width 0.312 in.13 Degrees of MisalignmentRadial Load Capacity 2851 LBS AB4/AM4Ball Width 0.375 in.16 Degrees of MisalignmentRadial Load Capacity 5260 LBS AB5/AM5Ball Width 0.437 in.14 Degrees of MisalignmentRadial Load Capacity 7639 LBS AB6/AM6Ball Width 0.500 in.12 Degrees of MisalignmentRadial Load Capaci
            • Timothy B.
              • April 30, 1983
              • 5186
              Richard,
              Why not straighten the strut rods and press in new bushings along with new hardware (bolts etc.) Much less $$ and will work out great.
              • Richard L.
                • November 1, 1984
                • 194
                Am I right in assuming that I have to piece together my own strut rods in order to use the heim joints you recommend? In other words, buy the rods, discard the polyurethane ends and substitute the heim ones? Sounds complicated and a bit on the expensive side. Frankly, I was hoping to buy them alltogether, already assembled, from one of the familiar vendors and ready to install--not possible?
                • Tom E.
                  • June 1, 2019
                  • 448
                  Richard,
                  perhaps this is what you are looking for.
                  https://www.jegs.com/i/Global+West/4...ABEgKrGfD_BwE#
                  Tom
                  • Jim L.
                    • 1808
                    Originally posted by Tom England (65936)
                    Richard,
                    Tom
                    Those will work well.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      I ordered replacement OEM-style 63 strut rods from Paragon and then decided to rebush and reuse my originals...by the time I was done fighting and torching out the old bushings and hand-cranking the NOS bushings in (I don't have a press - see pics) the repros arrived and were so nice I wish I had waited and just bolted those on - -- VERY well done repros IMO. Nice bushings and nice bare metal examples...
                      • Richard L.
                        • November 1, 1984
                        • 194
                        It sounds like I'd be miles ahead getting the Paragon repros--correct, less expensive and likely easier to install. The JEG'S adjustable are very nice and would certainly work better but my '63's have lasted for 58 years. Frank, can you tell me the part # from Paragon?
                        Ric
                        • Leif A.
                          • August 31, 1997
                          • 3627
                          Ric
                          Paragon:
                          https://www.paragoncorvette.com/p-35...it-rubber.aspx
                          Long Island Corvette:
                          Leif
                          • Frank D.
                            • December 27, 2007
                            • 2703
                            Yes, Leif above is the one that turned me on to the Paragon repros and he has provided the link for them.
