I am trying to formulate theories on the date coding of Firestone tires from 1966 to 1970. I have a lot of data I have acquired over the years from original spare tires and wheels I have owned and original spare tires and wheels I have observed over the years.
The coding appears to be in the tire identification code (TIC) impressed into the back of the tire. From what I have observed, the TIC appears to be in the format of three numbers followed by two letters followed by three numbers for Firestone Nylon cord tires. The first three letters are usually 000, 001, or 002. I am guessing the two letters are date codes with the first letter being the month and the second letter being the year. 1966 steel wheels and 1967 and early 68 rally wheels do not have date codes stamped by the valve stem. Later 68, 69, and 70 wheels have date codes stamped into the wheels. These date coded wheels can give us data on the month coding.
I am theorizing the year codes (the second letter in the TIC) are as follows based on the data I have observed.
1966 second letter is coded E
1967 second letter is coded R
1968 second letter is coded C
1968 second letter is coded L
1970 second letter is coded A
I would like to write an article in the Restorer magazine on Firestone date codes for 1966 to 1970. If you have a low mileage C3 (1968-1970) with original tires (I have only seen 1 car with original tires) or an ORIGINAL spare tire and wheel, I would like to have the data off the tire and wheel for my data base and the for article. I have enough data from original 1969 spare tires and wheels to begin formulating a theory on the month coding, which in all likelihood is the same for the other years.
Your help would be greatly appreciated.
Howard Key (2718)
Howard Key (2718)
