66 outer heater box nuts - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 317
    Hi , looking to find the correct outer heater box nuts . AIM says part # 446069 for two of them and 9419845 for the others
    The vendors sell a 1/4 20 nut with a serrated flange washer . any help would be great
    thanks Bob
  • Gary B.
    • February 1, 1997
    • 7046
    • Robert P.
      • October 19, 2019
      • 317
      Re: 66 outer heater box nuts
      thanks for the info , where can they be bought , the ones sold by paragon and LIC are reg nuts with a shoulder
      thanks Bob
      • Gary B.
        • February 1, 1997
        • 7046
        Bob,
        AMK sells them in black phosphate, but their minimum order is $30, plus $10 S&H. So, not cheap
        Gary
        • Ronald L.
          • October 18, 2009
          • 3248
          I don't think you have to look too much further to find less than $5 kits with the correct parts.
          • Robert P.
            • October 19, 2019
            • 317
            Ron , can you tell me where that might be
            Bob
            • Ronald L.
              • October 18, 2009
              • 3248
              Due to criticizms of the suppliers by some - the love hate for many on the forum - I will not post any more, email me from your control panel.
              • Leif A.
                • August 31, 1997
                • 3642
                Robert,
                A/C heater box or non-A/C heater box?
                Non-A/C heater box nuts...
                Leif
                • Gary B.
                  • February 1, 1997
                  • 7046
                  Leif,
                  I wonder if the Pal nuts in LIC kit 37-03 are accurate reproductions of the two GM nuts that Bib asked about. The reason I say that is the following. If the ANK specs are correct then the OD of GM 9419845 should be 85% (= 0.69/0.82) of the OD of GM 446069. If you scale the nuts in the LIC kit you get a ratio of 0.75. The two LIC nuts are more dissimilar in size. So who is right? LIC or AMK?
                  Gary
                  • Bob R.
                    • June 30, 2002
                    • 1595
                    I got a heater box rebuild kit from Doc Rebuild last year and I believe he had the correct PAL nuts. I think he is closed during this pandemic.
                    • Gary B.
                      • February 1, 1997
                      • 7046
                      Bob,
                      I think a lot of people are hoping and waiting for Doc Rebuild to come back online. He has some parts that are more correct if not totally correct that some of the other companies fall short on.
                      For the Pal nuts, if AMK Products sells correct ones, then, in my opinion, there is no excuse for the main Corvette repro parts companies not to sell correct kits. Other than cutting corners to cut costs.
                      Gary
                      • David B.
                        • March 1, 1980
                        • 689
                        [QUOTE=Gary Beaupre (28818);889652]Leif,
                        GM # 446069 1/4-20 Flange diameter. .812
                        GM # 9419845 1/4-20 Flange diameter. .687
                        Overall height of both .292 Stock thickness of both .021 Both phosphate coated GM 4435-M Code A. Slight differences in other areas.
                        • Gary B.
                          • February 1, 1997
                          • 7046
