1964-1965 327 Engine Harness Lectric Limited VIG6465 Pink vs. Black/Purple Coil Wire - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2151
    LL part number VIG6465 (instruction sheet INS8346) shows a "Black/Pink: "R" Terminal attachment at the starter solenoid. This wire routes to and from the COIL (+), on its way to the ballast resistor . I believe this wire should be pink. (In fact, the instruction sheet says "pink" at the coil end.)
    What am I missing here?
    Thanks.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • 6960
    Re: 1964-1965 327 Engine Harness Lectric Limited VIG6465 Pink vs. Black/Purple Coil W
    Tom, I think that pink wire branches from coil+ To ballast and The other heads into the starter R terminal. As you state. I believe both were pink.
    • Alan D.
      • January 1, 2005
      • 2054
      Tom, what year are you working on?
      • Tom D.
        • 2151
        '65 number 11843
        Michigan Chapter
        Tom Dingman
        • Joe R.
          • July 31, 1976
          • 4552
          Tom,
          Your first mistake would be using a Lectric Limited instruction sheet and your next mistake would be to use their wiring harness!
          JR
          • Alan D.
            • January 1, 2005
            • 2054
            OK, so color SB "pink" according to GM wiring diagrams!
            • Garry B.
              • January 1, 1991
              • 667
              Tom, as mentioned before, I can confirm that the '64 wire that you mention is black and pink striped. I don't know if this carried over to '65.
              Garry Barnes #18531
              '67 Lynndale Blue Coupe- National TF, BG
              ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
