Brake Calipers - What would you do? - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    In assessing the brake calipers in my 69 for which I am beginning a restore I have determined the following. I have not checked the casting numbers for any of the inside halves but looking at the outside halves the only numbers that are correct are the left rear caliper. I know for certain the two front calipers were replaced and the right rear is not a correct number....looks to be something off an early 70s Chevy something or other. Car has been sitting 20 years and mechanic working with me on this suggests replacing all caliper seals. I would like to over time get the car as "correct" as possible. The pads on both rears are pretty well shot so those pads need replaced now. So do I keep the left rear caliper and replace its seals...cuz that caliper is original...and replace the right rear caliper with a new correct casting one? Or for symmetrical performance or other considerations scrap what may be the only original caliper and replace both rear calipers thereby skipping the seal replacement altogether in the process? Am planning to replace both rear rotors in any scenario.
    When it comes time to do front brake work...its an easier decision as neither caliper is correct so just replace both with new correct ones.
    I realize some of this may be "depends what your objectives and restoration philosophy are". Not new to cars by any stretch but this is my first resto which I may...years down the road...want to have judged....so value any and all perspectives on balancing originality vs performance vs correctness....vs...anything else!!
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
    • 11698
    Re: Brake Calipers - What would you do?
    If it were my car, I’d have Lonestar send me a set of 4 correctly numbered calipers, send your 4 back as cores, and move on with life.
    • Bill M.
      • 1329
      Kieth I have no idea how much correct numbered calipers cost if they are expensive I would go with a delco replacement and put the money into more visual parts. Just my opinion.
        • 11698
        The cost difference from Lonestar is nominal.
        Since they are the license holder for the reproduction castings, they also seem to charge the least to get the correct numbers.
        This may sound obvious, but also request them in black if you're ordering a set.
        If you call they are very willing to help.
        • Keith B.
          • September 15, 2014
          • 1604
          What Patrick said. Call Ken at Lonestar and he will fix you up
          • Bob D.
            NCRS Shipping Data Report Manager
            • April 30, 1996
            • 798
            I agree with Patrick. Ken at Lonestar is very helpful.
            Bob
            • Keith M.
              • January 17, 2021
              • 695
              Well...I know good advice when I hear it. I will give Ken a call on Monday. Couple followup questions...points.
              Zip has correct number calipers for $190 per...no core charge... not sure what Lonestar prices would be....any time I click on any product on their website I get a blank page. But with all the recommendations to go to Lonestar and them being THE license holder...that has value to me...means they know how to do it right.
              As for rotors...any reason to get those from Lonestar? Again Zip has for stock rotors for $60 per. Is Lonestar better quality. In any case I will discuss those with Ken as well. Will also consider them for other products...just wish their website was "functional"...ie. provide more product detail and pricing.
              • Don H.
                • December 1, 1981
                • 1498
                I just spoke to Lonestar last week and their website is being rebuilt. Don H.
                • Larry M.
                  • January 1, 1992
                  • 2702
                  Lonestar may well supply Zip and other part dealers. They ARE the source today. They now deal wholesale, but will sell retail to us Corvette guys and others if asked. Ken is the guy to talk with if possible. He is the owner/manager.
                  Larry
                  • Keith B.
                    • 1604
                    I would call Zip and see who they drop ship the calipers from. For the rotors I would buy them local at you local parts store
                      • 11698
                      I would not replace your rotors unless you measure them and they are already worn below spec. I don't anticipate that will be the case.
                      You do NOT want to separate the rotors from the hubs unless you absolutely have to.
                      Local repair shops can likely machine your front rotors while still attached to the hubs.
                      Your rears will be redone when you send out the trailing arms.
                      As noted above, the Lonestar website is having issues.
                      Ken just emailed me and told me that he's having a whole new site built, so to call with questions.
                      • Owen L.
                        • September 30, 1991
                        • 893
                        When I inquired in May of last year, correct core casting number calipers were a $20 up-charge each -- to dig through the bins as Patti put it.
                        Perhaps their new website, when up and running will allow ordering, but in May it was explained that they are wholesale and the website is not for retail customers so to call or email them and tie it back to Corvettes.
                        Patti Lewis
                        11299 Interstate 20
                        Canton TX 75103
                        patti@lonestarcaliper.com
                        903-829-8400 903-829-8405 fax
                        • Dennis H.
                          • September 30, 2005
                          • 226
                          When I need a caliper I go to the local FLAPS, never had a problem with them leaking.
                          • James W.
                            • December 1, 1990
                            • 2676
                            • Brad Hillhouse (37766)
                              You can also buy direct from Lonestar thru their eBay store. Search for seller edgewoodmike2012
