Cdcif - NCRS Discussion Boards
Cdcif
  • Jimmy G.
    • November 1, 1979
    • 977
    Cdcif
    I am going to open a can of worms with this post.
    The Carolinas Chapter is having a Judging School Saturday on the process of judging several parts using the CDCIF method used by NCRS. In thinking about it, unless a part is installed incorrectly, there can never be a 100% TOTAL DEDUCTION. We all know that that is only technically correct. I would like to hear opinions about this for our discussion Saturday.
    Second issue. If a part has no date but is determined to be a service replacement part, can you technically deduct 20% for the date that does not exist. I know how I handle this but I would like to hear the opinion of other MASTER JUDGES and or Team Leaders.
  • Harry S.
    • July 31, 2002
    • 5344
    Re: Cdcif
    Jimmy, just some ideas.
    A mustang hubcap on a corvette is a 100% deduction.
    On C1's when checking the glass on the door mirror use a cred card. If you hold the credit card against the glass and there is a space between the CC and the image, it's time period correct. If there is no space, you have a date problem, implied date, as mirrors of that era all silvered the glass the same way and you got a space. There are other examples of implied date.
    • Michael J.
      • January 27, 2009
      • 7166
      Re: Cdcif
      A can of worms indeed Jimmy! I have heard one high point master judge opine that if the configuration is wrong, all the other items should get full deductions.......so he believed yes, you can get a 100% deduction.....
      • Don H.
        Moderator
        • June 16, 2009
        • 2281
        Re: Cdcif
        Hi Jimmy
        see my comments in this thread on motor mounts, only a few lines below yours. You absolutely take Date on a service replacement part (a you know). And on an obvious reproduction (in most cases) when there are Configuration differences from the OEM original part.
        https://www.forums.ncrs.org/showthre...n-motor-mounts
        • Brian D.
          • April 30, 1999
          • 425
          Re: Cdcif
          Doesn't the Standard Deduction Sheet override CDCIF specs?
          There are multiple items on the Standard sheet which list a 100% deduction option.
          Also, missing items can't receive any point credits.
          I am not a fan of the implied date codes, but I understand how they can be a factor,
          and so I do use them.
          B.D.
          • David H.
            • June 30, 2001
            • 1559
            Re: Cdcif
            Originally posted by Jimmy Gregg (2756)
            ...using the CDCIF method used by NCRS. In thinking about it, unless a part is installed incorrectly, there can never be a 100% TOTAL DEDUCTION. ....
            Second issue. If a part has no date but is determined to be a service replacement part.....
            Jimmy
            Originality of parts are first judged by Standard Deduction Guidelines (SDG). If NO SDG exists for the item in question, then judging Originality reverts to our C.D.C.I.F. Matrix judging system. In particular, Engine Block, Batteries, Tires, Windshields, Headlamps, Trim Tag, Body Color, Body Paint, and Body Fiberglass are all evaluated by Standard Deduction Guidelines - No C.D.C.I.F.
            Other Standard Deduction Guidelines provide direction to C.D.C.I.F. Matrix judging when you encounter certain situations. SDG #6 Stainless/Aluminized, SDG #7 Altered Cars, SDG #9 Added & Deleted Options, SDG #13 Replacement Parts, SDG #14 Dealer Installed Accessories, and SDG #15 Factory Recall Modifications, all provide judging guidance when using C.D.C.I.F. Matrix judging.
            SDG #13, especially, provides guidance on judging Service Replacement, NOS, and after-market parts. Note language on judging "Significantly Dissimilar" parts generating 100% deductions.
            I am away from my Restorer Magazine resources at this time so I cannot give you a reference volume, however, David Brigham's Restorer article on judging replacement parts DATE are worth re-reading. (Material was also presented during Judges Retreat/Regional judging schools) Minor Configuration issues (20% Configuration deduction) on undated parts (e.g. door panels) do not in-turn, also generate a Date deduction.
            Configuration, as one element of our C.D.C.I.F. matrix, would generate a 20% deduction - not 100%. Configuration issues can also identify Date issues, but Completeness, Installation, and Finish should not be lumped into the mix "just because".
            Dave
            Judging Chairman Mid-Way USA (Kansas) Chapter
              • 15631
              Re: Cdcif
              Jimmy
              I am glad you asked because both these questions are often asked int he Advanced Judging Seminar, and they are an area of some misunderstanding.
              I wish we had the "like" button on here like other sites do.
              • Jimmy G.
                • November 1, 1979
                • 977
                Re: Cdcif
                What is your opinion on these issues?
                • Joseph S.
                  National Judging Chairman
                  • March 1, 1985
                  • 928
                  Re: Cdcif
                  Jimmy, We have a term for items that might require a full or 100% total deduction. "Significantly dissimilar" If the part has no attributes that the original part had it can be a full deduct part. A K & N air filter is a filter, fits the air cleaner and could be installed correctly.....however, it is for sure a full deduct part.
                  Date could be implied by the configuration of a part. However, we have to tread lightly on parts that do not carry a stamped or cast part number. Never take a date deduction for a known Reproduction part if it was reproduced for that model. For instance, if you determine that the carpets are reproduction because of the loop or binding, we don't take date. That part was reproduced to fit that model, it just has a slight, or not so slight configuration issue. We are trying not to hammer on our reproduction suppliers. Now there are some service replacement parts that may qualify for a date deduction. This is because GM used service replacement parts to fit multiple cars and multiple years. The service replacement part was not specifically made with the intent to fit a certain year or model. It is more universal than that. It's a tough subject to get clear in one paragraph. I hope you can grasp this.
                  • Brian D.
                    • April 30, 1999
                    • 425
                    Re: Cdcif
                    Joe,
                    Thank you for those descriptions!
                    I will keep these things in mind whenever I debate applying the "implied date" deductions.
                    B.D.
                    • Mark F.
                      • July 31, 1998
                      • 1595
                      Re: Cdcif
                      Originally posted by David Houlihan (36425)
                      Jimmy Originality of parts are first judged by Standard Deduction Guidelines (SDG). If NO SDG exists for the item in question, then judging Originality reverts to our C.D.C.I.F. Matrix judging system. In particular, Engine Block, Batteries, Tires, Windshields, Headlamps, Trim Tag, Body Color, Body Paint, and Body Fiberglass are all evaluated by Standard Deduction Guidelines - No C.D.C.I.F. Other Standard Deduction Guidelines provide direction to C.D.C.I.F. Matrix judging when you encounter certain situations. SDG #6 Stainless/Aluminized, SDG #7 Altered Cars, SDG #9 Added & Deleted Options, SDG #13 Replacement Parts, SDG #14 Dealer Installed Accessories, and SDG #15 Factory Recall Modifications, all provide judging guidance when using C.D.C.I.F. Matrix judging.
                      SDG #13, especially, provides guidance on judging Service Replacement, NOS, and after-market parts. Note language on judging "Significantly Dissimilar" parts generating 100% deductions...................Minor Configuration issues (20% Configuration deduction) on undated parts (e.g. door panels) do not in-turn, also generate a Date deduction...........Configuration, as one element of our C.D.C.I.F. matrix, would generate a 20% deduction - not 100%. Configuration issues can also identify Date issues, but Completeness, Installation, and Finish should not be lumped into the mix "just because". Dave
                      Hi Dave,
                      Does the attached Table correctly outline approximate deduct values using SDGs and CDCIF as you indicate above?
                      thx,
                      Mark
                      • Joseph S.
                        • March 1, 1985
                        • 928
                        Re: Cdcif
                        Terry, I would say it's an area of GREAT misunderstanding.
                        • David H.
                          • June 30, 2001
                          • 1559
                          Re: Cdcif
                          Originally posted by Mark Francis (30800)
                          Hi Dave,
                          Mark
                          Numbers appear to be divided out correctly, but I'm not sure how useful this table would be in practice. Problem is assignment of points on lines with multiple elements. For example, water pump and fittings. If the water pump is ok but there is an issue with the fittings, then total points first get spread over those two items. Judges determine point spread among multiple items by weighting those items as they see fit. Appropriate C.D.C.I.F. percentages are then taken against the weighted items.
                          In theory a comprehensive deduction table could be developed, but in practice it would be unwieldy. Easy enough for you and your judging partner to spread total points over items in question, then divide those points by 5 to determine what a C.D.C.I.F. deduction value would be. Try to keep the math simple - small point over/under deductions tend to offset.
                          Dave
                          • Joseph S.
                            • March 1, 1985
                            • 928
                            Re: Cdcif
                            Dave, Well said!!
                            Joe
                            • Mark F.
                              • July 31, 1998
                              • 1595
                              Re: Cdcif
                              Mark ....Numbers appear to be divided out correctly, but I'm not sure how useful this table would be in practice. Problem is assignment of points on lines with multiple elements. For example, water pump and fittings. If the water pump is ok but there is an issue with the fittings, then total points first get spread over those two items. Judges determine point spread among multiple items by weighting those items as they see fit. Appropriate C.D.C.I.F. percentages are then taken against the weighted items. .....In theory a comprehensive deduction table could be developed, but in practice it would be unwieldy. Easy enough for you and your judging partner to spread total points over items in question, then divide those points by 5 to determine what a C.D.C.I.F. deduction value would be. Try to keep the math simple - small point over/under deductions tend to offset. Dave
                              Hi Dave,
                              Got it...what you say makes perfect sense...experience, a good partner, and a calculator may be useful with the CDCIF system
                              thx,
                              Mark
