Anyone have a C1 Four-speed shifter removal procedure? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: Anyone have a C1 Four-speed shifter removal procedure?
    There are 2 special nuts that are inserted into rectangular holes for the plate screws.
    The page you were looking for was not found or has been deleted. Search Corvette Parts by year or category instead.
    • Keith R.
      • August 31, 2001
      • 660
      Now I get it. Thanks Rich. I couldn't picture that.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      2013 427 Convertible
      Shade tree mechanic and
      B-52 pilot extraordinaire
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        #18
        To install when the shifter is there, put a screw in it and fish it in position with needle nose pliers, grab the screw to hold it.
        Then use a small tool to push the tabs inward to lock it in place.
        Rich
        • Thomas F.
          • November 11, 2008
          • 204
          #19
          I removed the transmission tunnel access panel that surrounds the shifter. It was not an easy task but next time will be a breeze. The panel is held on by several screws around the edge and is also attached with sealer which I had to remove with a chisel and puddy knife. Thanks to Richard Mozzetta for his input which helped me on this issue.
          • Mike E.
            • February 28, 1975
            • 5138
            #20
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              #21
              Thomas, Glad I was able to help, thanks for the note.
              FYI, this was your original post re the tunnel cover I think you are referring to.
              Rich
              • Leo G.
                • August 31, 1987
                • 116
                #22
                FWIW those special nuts that Richard refers to are available at a GOOD hardware store. They are 10-32 thread size and are about $2.50 each. Shifter pattern plate covers the screws. I installed so in my 61.
                Drive em safe
                Leo
