Interior leather brightness influence upon NCRS points - NCRS Discussion Boards
  • Martin T.
    • May 31, 2006
    • 196
  • David H.
    • June 30, 2001
    • 1545
    Re: Interior leather brightness influence upon NCRS points
    Originally posted by Martin Tait (45941)
    I am in need of new white leather seat covers for my 65. Al Knoch has bright white leather in stock but they would need to special order the white currently on the seats. .... I don’t remember the original white leather used in 64/65 but doubt it was “bright”.
    Martin
    What is the interior code on your Trim Tag?
    Standard Deduction Guideline #7 covers ALTERED CARS. (See link below, Section 4 - #7). Changes in interior color or fabric would generate a 50% deduction. Changes in interior color and fabric would generate a 100% deduction.
    For a definitive answer, contact 1965 National Team Leader K.C. Strawmyre (kcsvpr@gmail.com).
    Dave
    • Martin T.
      • May 31, 2006
      • 196
      Dave, Thank you for your response. The original interior color is white. The question I have is the brightness of the white. Currently, Al Knoch is stocked with a bright white. The brightness is not the same as the original leather used. Would there be a point deduct for the intensity of the white?
      • Joe R.
        • July 31, 1976
        • 4551
        In a case like this just take what you can get! A few points should not effect the difference between a top flight and second flight! If a few points get in the way you should just fix what you can and have a good enough Corvette that a few points won't matter anyway!
        JR
        • Harry S.
          • July 31, 2002
          • 5334
          Seats, back & trim are worth 24 points. If a judge splits 20 for the seats and 4 for the back and trim. The hit out of CDCIF is the F (finish) or 20% of 20 points. So figure its around a 4 point hit. You still have 4506 points to play with.
          • David H.
            • June 30, 2001
            • 1545
            Martin
            "... The brightness is not the same ..." is why I recommend you contact 1965 Team Leader.
            If current Al Knoch leather is considered to be a color change, then judging is NOT based on C.D.C.I.F. Judging, in this case, will be based on Standard Deduction #7 - Altered Cars -- a 50% deduction.
            If Al Knoch leather is NOT considered to be a color change, then judging would be based on C.D.C.I.F. Matrix judging. Given all other matrix elements ( C.D.C.I.) have no issues, you might have a Finish "F" - color - issue -- a 20% deduction.
            Contact K.C. for a definitive answer.
            Dave
            • Michael J.
              • January 27, 2009
              • 7157
              WhiteSeats.jpgI'm really not sure what bright white leather looks like vs. what might be more original. Here is a shot of my '64 that went through Nationals a couple of years ago with no deductions.....
              • Jaime G.
                • April 1, 1988
                • 480
                Martin,
                If 4 points or so are important to you, then dont get the seat covers.
                More important, is the appearance of the seat finish acceptable to you.
                If it is, proceed with your refresh restoration. If not, order what you wish
                to have. Judging should not be the determining factor in my opinion but
                rather what you want for your car. The brightness should not be a major
                issue unless it makes the seats appear not white which would be a color
                change. Best of luck.
                • Reba W.
                  • 938
                  Isn't it quite possible that the 55-year-old seats have aged (like a lot of us) until they do not appear as they once did?
                  • Michael J.
                    • January 27, 2009
                    • 7157
                    Absolutely! Here is a photo of my '64's original white leather seats after being pulled out of a barn after sitting for decades. Compare that to the one I posted above of the restored seats from Al Knoch.....
                    • Martin T.
                      • May 31, 2006
                      • 196
                      Harry, I don’t have an objection to bright white if that was the original sheen. So much time has been spent on the car that I did not want to go in a direction that would compromise efforts already made. The car is one of the first ten. Those first cars were not production nor pilot line (as the pilot line cars were used to check for fluidity in the production process for the new model year, utilizing the final production features). The first ten were made to approximate the intended production styling but did not incorporate all the production features. In this light, I would like to go for originality and minimum point loss at judging.
