L82 Cam Replacement Question - NCRS Discussion Boards
  • Dennis H.
    • September 30, 2005
    • 226
    Hi
    As I build my shopping list to put my 73 L82 car back to OEM standards I'm at the cam & lifters part of this. I have the original cam and lifters that came out of the car and they have about 40K or less miles on them. I inspected the camshaft and lifters and there is zero noticeable wear, lifter faces are flat and very clean. What I don't know is what hole each lifter came out of.
    My options are;
    1) Use the original cam and lifters that came out of engine.
    2) NOS cam and lifters $400
    3) Reproduction cam and lifters $200
    I really want to go with option 1, your thoughts?
    Looks like the L82 cam and lifters are on GM Parts Direct for $455.00
    Dennis
  • Mark E.
    • April 1, 1993
    • 4597
    Re: L82 Cam Replacement Question
    Reorienting used lifters on a used camshaft is risky. Without knowing the original position of each lifter, you'll need a new cam and lifters.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Dennis H.
      • 226
      Yes that was my thoughts as well. Any insight on the cam from GM Parts Direct?
      • Thomas H.
        • August 31, 2005
        • 1060
        As long as the cam is in good shape you can install new lifters - along with some assembly / break in lube.
        Old lifters on new cam - no no
        Old cam, original lifters - ok as long as the lifters go back on the SAME lobe they came from
        Old cam, original lifters but mixed up - no no
        Tom
        2007 Z06, Lemans Blue
        • Larry M.
          • January 1, 1992
          • 2700
          I have personally run an old cam with new lifters with no apparent issues. But some folks say this is risky. I used plenty of moly lube on the lifter faces and some EOS in the oil. And all was well.
          Maybe try the lifters with the small oil hole drilled/laser cut in the lifter face for added assurance.
          But do NOT run the old cam with the old lifters in the wrong holes.
          Larry
            • April 1, 2000
            • 477
            Another vote for used cam with new lifters as above. I've done this a few times with no issues.
            • Dennis H.
              • 226
              Thanks for the help.
              • Dennis H.
                • 226
                Did some dumpster diving using the search function on all things lifter related and the general consensus is the Sealed Power HT817 lifter is a good replacement for the GM 5232720 lifter.
                The GM 5232720 is $12.66 EA while the Sealed Power are $4.99 EA. From everything I have read I'm not seeing the justification of spending the extra money for the GM lifter.
                Am I missing something here?
                Dennis
                • Dennis H.
                  • 226
                  Well I decided to go with a new GM 3896962 cam and 5232720 lifters (ACDelco HL66). Had to do a little dumpster diving around the internet to find stock and not use GM Parts Direct and get soaked on shipping.
