65 with AC - Battery Disconnect Switch - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 409
    Looking for advice and/or recommendations on installing the Wirth top post battery disconnect switch on my "soon to be completed" '65 coupe with air conditioning (&C60) frame off restoration. . . .
    Here's what I'm trying to determine before my purchase:
    1) Since I am planning on installing it on the negative battery post and with the battery located below the power brake booster, is there any part interference concerns that I should be aware of?
    2) Is the horizontal lever switch or the vertical lever switch preferred?
    Wirth - Top Post Horizontal Disconnect Switch - 08Feb21.jpgWirth - Top Post Vertical Disconnect Switch - 08Feb21.jpg
    Any thoughts and/or recommendations are appreciated.
    Thanks in advance.
    Ray K
    NCRS Member #43777
  • Harry S.
    • July 31, 2002
    • 5346
    Re: 65 with AC - Battery Disconnect Switch
    I think you should be fine. I have one on my 63.
    Oops, the negative cable is different on yours as I recall.
    • David M.
      • September 30, 2004
      • 533
      Negative cable, yes.
      I prefer this style. A bit more compact and I can completely unscrew the green knob and take with with me at a show.
      There are 2 quality levels of this part. Chineasium usually $5-6. And the good one Belden Napa Corvette Central et al...$20+
      • John F.
        • March 23, 2008
        • 2424
        Here is the orientation I had in my 64 coupe w/ac and power brakes. It fit just fine.
        • Ray K.
          • April 30, 2005
          • 409
          • Frank D.
            • December 27, 2007
            • 2703
            Originally posted by Ray Krawczyk (43777)
            Harry, Dave & John,
            Thanks a bunch for your thoughts, recommendation & jpegs.
            It’ll be the Wiron with the vertical vertical lever for my ‘65 w/AC. . . .
            Ray
            Good move, I've had two of the green/black knob flizzes fail over the years (not the cheap ones either); seems over time I had to crank down harder and harder on the knob to make good contact and eventually even that wasn't good enough to make a strong enough circuit to start the car. Been using the knife blade switch for 7 years now and no issues.
