Fiberglass staining question - NCRS Discussion Boards
  • Steven L.
    • November 7, 2016
    • 32
    Hi all,
    I'm well along in the process of making fiberglass repairs to the nose of my '66, and my next step is to do some filler work. Two years ago, in preparation for making these repairs, I stripped the paint off the body, down to the fiberglass, and with the exception of the areas I've been working on, the rest of the car has been masked off and/or covered. This morning I removed some of the masking to expose the fenders and cowl, and I noticed that the fiberglass looks dark, like some type of staining, that goes across the top of the cowl, and is also present on the lower portion of the left fender. I haven't tried to clean the affected areas yet, so I wanted to ask if anyone has experienced this issue, and if so, how did you address it.
    Thanks for the assistance!
  • Tom E.
    • June 1, 2019
    • 448
    Re: Fiberglass staining question
    Steven,
    A few photos of the affected area would help possibly identify the cause.
    Tom
    • David H.
      • June 30, 2001
      • 1559
      Originally posted by Steven Leunig (62965)
      . .... Two years ago ... ... I stripped the paint off the body, down to the fiberglass, ... the rest of the car has been masked off and/or covered. This morning I removed some of the masking to expose the fenders and cowl, and I noticed that the fiberglass looks dark, like some type of staining, ...
      Steven
      Original fiberglass or a replacement?
      Method & material used during stripping?
      Material used to cover stripped areas?
      Storage? (Wide temperature / humidity variations)
      Any coloration difference between masked areas and covered areas?
      Dave
      • Steven L.
        • November 7, 2016
        • 32
        Will do. This is my first attempt at attaching a picture, but I don't see a button for it. How do I do it?
        • Stephen L.
          • May 31, 1984
          • 3162
          Click on "Reply to thread", Scroll down to Click on "Go Advanced". Click on "Manage Attachments". Click on "Add files". Click on "Choose File".
          Select the file (photo in your file). Click on "Upload". Once your photo appears click on "Done". Now your photo ID will appear below "Manage Attachments"
          Click on "Preview Post" to see if what you have selected is what you want in your post..
          You can select more than one photo before you click on "Done" above...
          If you are satisfied with your "Preview" click on "Submit Reply"
          Your post will appear in the original thread list
          Steve
