TIMJG Page 226 of the 70-72 6th edition clarification question - NCRS Discussion Boards
  • Stan B.
    • September 24, 2020
    • 66
    Hello again everyone.
    On page 226 of the 70-72 6th edition TIMJG it shows a list about the front spring broadcast codes
    What does it mean:
    350 under 720 3931823 HS
    350 over 720 3931824 HT
    I realize there are different part numbers but what does "under 720 and over 720" mean???
    Thanks and sorry if this is an obvious question.
  • Ron G.
    • December 1, 1984
    • 866
    Re: TIMJG Page 226 of the 70-72 6th edition clarification question
    Could possibly be PSI.
    "SOLID LIFTERS MATTER"
      • 15630
      Stan & Ron
      I think the value is pounds per inch of travel, but I will have to do some checking when I get home.
      • Jeffrey S.
        • May 31, 1988
        • 1898
        I think it has to do with the weight each wheel carries. You start with a base for a car with no options and add the weight of each option. These weights are in the shop manual.
          • 43272
          Jeffrey------
          Correct. That's what it refers to. It's also in the AIM's.
            • 6955
            Stan the broadcast codes HS/HT one is for A/C and the other is w/o. A/C. Correct me if I am wrong guys.
              • 43272
              Edward-------
              I think what it amounts to is that it usually requires A/C to get to the "over 720". However, there may be other combinations of options that would also get a car to "over 720".
                • 15630
                Jeffrey------
                I agree. Too bad we don't have a "like" button here.
                • Stan B.
                  • 66
                  Fascinating stuff!
                  Thank you all.
                  • Mark F.
                    • July 31, 1998
                    • 1589
                    Edward-------I think what it amounts to is that it usually requires A/C to get to the "over 720". However, there may be other combinations of options that would also get a car to "over 720".
                    Guys - I guess I'm just not following -
                    the lightest front curb weight I see for a '70, '71 or '72 is 1,574 lbs. (1970 conv.).
                    1,574 lbs./2 is 787 lbs. split between both front springs.
                    That's already over 720 lbs. with no added option weight.
                    What am I missing here?
                    How do we get below the 720 per side if the base car is already over that?
                    PS - have not had any coffee yet
                    thx,
                    Mark
                      • 15630
                      Here is where that information in the 1970-72 TIM&JG came from: The 1970 AIM.
                      • Mark F.
                        • July 31, 1998
                        • 1589
                        [ATTACH=CONFIG]104349[/ATTACH]
                        thx,
                        Mark
                          • 15630
                          There is also the fact that the spring is not at the outboard end of the control arm.
                          No coffee here, and not enough sleep either.
