1966..Sidepipes-- Factory installed or added on later? - NCRS Discussion Boards
  • Bill M.
    Infrequent User
    • December 14, 2020
    • 21
    Were my side pipes (N14) factory installed or added later on?
    I have a 1966 Coupe 427/425H HP Coupe. Lots of factory options on this car. A lot more than someone would normally order.
    I have no history of what options came car came with..only what appears to be factory installed inside and not underneath.
    My question is, how can I tell if the side pipes (N14) were factory installed or added on later?
    The car is going into the shop next month for a tune up and I will have a chance to have it up on the rack
    to look at the underneath and take pics.
    What can I look at or where should I look to see if they were factory originals or if the muffler system was removed and the pipes added later on?
    Any suggestions of bolts, nuts, holes, brackets, welds, look at this, look for that, etc would be greatly appreciated.
  • Harry S.
    • July 31, 2002
    • 5349
    Re: 1966..Sidepipes-- Factory installed or added on later?
    Post your email address and I'll send you a PDF file that is too large to upload to the website.
    • Gary B.
      • February 1, 1997
      • 7087
      Bill,
      Do you have the latest edition of the 1966 Technical Information Manual and Judging Guide? If not, it would be useful to get. On page 194 it lists 9 things to look for to assess if side exhaust was original vs added after production.
      Does your car have an AO Smith body? If so, the answer is simple because no AO Smith bodies had side exhaust.
      Gary
      • Bill M.
        Infrequent User
        • December 14, 2020
        • 21
        It is a St Louis Body.
        • Gary B.
          • February 1, 1997
          • 7087
          • Bill M.
            Infrequent User
            • December 14, 2020
            • 21
            I do have the book but I am looking for things that can be pointed out with a quick look.
            As mentioned the car is going up on a lift next month so that I can verify some things including
            the pipes.
            • Gary B.
              • February 1, 1997
              • 7087
              the pipes.
              • Leif A.
                • August 31, 1997
                • 3658
                Bill,
                While not the best of pictures, here are a couple showing the notches in the frame. Also, look inside the rear wheel well for the crescent shaped cutout to clear the end of the pipe. Picture below of the passenger side.
                My apologies, "my frame showing the notches" pictures are in a format that this site will not accept.
                Leif
                • Tom E.
                  • June 1, 2019
                  • 448
                  Here is the link with images of the frame notches.
                  https://www.forums.ncrs.org/showthre...Birdcage+notch
                  • Bill M.
                    Infrequent User
                    • December 14, 2020
                    • 21
                    Thanks a lot. Basically this is the first and most important starting point (notches). I downloaded the pics along with along with some other notes (drilled holes-threaded etc) for when the car goes up on the lift.
                    Thx for the reply
                    • Gary B.
                      • February 1, 1997
                      • 7087
                      Thx for the reply
                      Bill,
                      Please let us know what you find out when you get to inspect the car on a lift.
                      Gary
                      • Gary J.
                        • April 1, 1980
                        • 1246
                        Once you have seen and feel real notches you can distinguish what is real and what is fake.
                        • Ralph P.
                          • February 1, 1990
                          • 253
                          Bill... Page A4 of the AIM shows the correct cuts . I believe there's a rear tab on the above photo that should be removed.
