Frame repairs - NCRS Discussion Boards
Frame repairs
  • Tim L.
    • January 1, 2005
    • 144
    Frame repairs
    I'm starting my minor frame repairs on my 66 L79 convertible restoration project. The end caps on the main frame rails are both rusted out. Are those welded ALL the way around? From the little material left on mine, it appears the corners were not welded. Looking for some photos of the end caps for reference. Thanks for any help.
    Tim
  • Leif A.
    • August 31, 1997
    • 3650
    Re: Frame repairs
    Note in the photo of my '67 below. On the driver's side end cap, the lower right corner is open to release moisture. On the passenger side, the lower left is open. Hope this helps.
    Leif
    • Don H.
      • December 1, 1981
      • 1494
      Re: Frame repairs
      Tim, You are welcome to come look at mine anytime. Don H.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11362
        Re: Frame repairs
        The amount of weld on those caps can vary quite a bit. I replaced these on a 67. You'll be surprised what you find in there and may have to make some repairs once inside. Best to use a coating to protect the inside cavity from future intrusion. Also coat the inside of the end cap before welding it in. A weld through primer works best so it doesn't burn off on the inside.
        If the body is on it's a bit trickier but doable. I did it on my 63 that way. Last pics, blue car.
        Rich
        • Frank D.
          • December 27, 2007
          • 2703
          Re: Frame repairs
          If its been on a Corvette, then Rich has dealt with it sooner or later...
          I coated both my 61 and 63 internal frame with 6 cans (each) of Eastwood's internal frame coating..
          Easy if you have a lift, messy but doable on jack stands:
          • Tim L.
            • January 1, 2005
            • 144
            Re: Frame repairs
            Don, don't worry I'm sure I'll be over a lot looking at yours for reference!! Tim
            • Tim L.
              • January 1, 2005
              • 144
              Re: Frame repairs
              Leif, that's exactly the information I was looking for! Thanks for the photos, also great to see what shows after the side pipes and body is on. I got mine from a given-up restoration start - body off and all taken apart. It is a factory side pipe car. Thanks, Tim
              • Tim L.
                • January 1, 2005
                • 144
                Re: Frame repairs
                Rich
                Rich, thanks for the photos of your process. Mine looks very similar as far as repairs. Both the inner and the end caps are gone on both sides. Interesting to see the two holes in the inner plate, I will add that to the pieces I have made. Tim
                • Tim L.
                  • January 1, 2005
                  • 144
                  Re: Frame repairs
                  Here is what I've roughed in on the passenger side. Hoping to get the end cap on this weekend and start on the driver's side. Thanks for the help.
                  Don't know why the photos rotated on me. Sorry!
                  • Tom E.
                    • June 1, 2019
                    • 448
                    Re: Frame repairs
                    Tim,
                    When I repaired my end caps I also replaced the corner gussets as they were weak as well. I noticed in your photo one of the holes appears eaten out. The preformed gussets are inexpensive and easy to install. Might be worth considering while your in there
                    Tom
                    • Tim L.
                      • January 1, 2005
                      • 144
                      Re: Frame repairs
                      Originally posted by Tom England (65936)
                      Tim,
                      Tom
                      [ATTACH=CONFIG]104217[/ATTACH]
                      Tom, I will definitely evaluate them. Thanks!
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11362
                        Re: Frame repairs
                        Tim I rotated your photos at the bottom to what I think what you intended. I've had the same cell phone photo issues. What I do is use MS Photo viewer to fix them, even if they are oriented correctly in that view. I view it, then rotate it so it's wrong, save it, then rotate back to correct view, then save again. Works every time. If you're uploading directly from the phone then based on Android, there are Rotate functions built-in. I use Android, not sure about the iPhone.
                        Those 2 holes in the internal mid cap support of the '67 are clearly seen and there's one partially visible on the '63 frame. The replacements didn't have them, and I didn't bother to drill them. I think they were there for additional airflow into the cavity. Didn't really help much on that '67 frame though did it?
                        Did you fabricate your own internal support? They have the flanges as original to weld to the side frame slots.
                        More of the '63 I did...
                        Your rotated photos....
                        • Tim L.
                          • January 1, 2005
                          • 144
                          Re: Frame repairs
                          Thanks for the tips Rich!!
