C2 Fan Shroud - NCRS Discussion Boards
C2 Fan Shroud
  • Enzo C.
    • January 12, 2012
    • 534
    C2 Fan Shroud
    I wanted some opinions on doing some minor repairs on a Original 67 BB Fan shroud
    some chips and a small strip is broken at the bottom
    What materials are best, mat, resin etc 4A0A9A4D-BB62-4E6C-9D20-76B7CAAC5610.jpg
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Garry B.
    • January 1, 1991
    • 660
    Re: C2 Fan Shroud
    Enzo, I noticed that you haven't received a response on this. Can you be a little more specific (maybe some close up photos) of what you are inquiring about? There are a few different forms of resin/fiberglass to choose from based on your application. You have the usual fiberglass mat that is soaked in resin and hardener and them laid down and recently I discovered a Bondo brand jelly that has fiber shreds already in the resin and it is used for smaller repairs. I have not tried the jelly, but the dry time is about 2 minutes and might be useful based on what you need. Might also be advisable to just leave it alone if it's not too bad.
    Garry (18531)
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
      • 6948
      • Garry B.
        • January 1, 1991
        • 660
        Re: C2 Fan Shroud
        Ed, very interesting idea. Does the JB adhere to the existing fiberglass well? Depending on the size of the patch, this could work really well. Not to steal Enzo''s thread, I am looking for ideas on how to recreate the bottom tabs on a '67 small block shroud. Most of them you see are broken off, so poor original design, but I may incorporate your JB idea somehow.
        Garry Barnes #18531
        • Enzo C.
          • January 12, 2012
          • 534
          Re: C2 Fan Shroud
          Hi Ed, that sounds like a really good idea... have you tried it ???
          Enzo Colosimo
          ENZ-Z06/67
            • 6948
            Re: C2 Fan Shroud
            Garry, yes JB weld works very well a and is stronger than fiberglass.
              • 6948
              Re: C2 Fan Shroud
              I should say to take a little sand paper and rough up a little.
