Firewall insulation - NCRS Discussion Boards
Firewall insulation
  • Eugene G.
    • July 31, 1982
    • 62
    Firewall insulation
    I ordered upper firewall insulation for my 64 and I received these two pieces. I can't fgure out how it is installed. It doesn't look anything like the picture in the AIM. Does anyone have a photo of this insulation on their car.
    Thank you
  • Tom E.
    • June 1, 2019
    • 448
    Re: Firewall insulation
    Eugene,
    Here is a photo of the installed firewall insulation. Larger piece to the left. Once you line up the holes it will make sense to you. I used 3M spray adhesive and it adhered very well.
    Tom
    • Eugene G.
      • July 31, 1982
      • 62
      Tom,
      Thank you very much. This photo will be very helpful.
      Thanks again.
      • Dave S.
        • August 31, 1992
        • 2930
        Hi Gene. Happy New Year
        Are you referring to upper or lower insulation or both.?? The lower insulation would have a skin of thick black paper.
        • Tom E.
          • June 1, 2019
          • 448
          Dave,
          his Photo shows the upper which I would assume that’s what he was asking about.
          To
          • Eugene G.
            • July 31, 1982
            • 62
            Hi Dave,
            It's the upper insulation.
            Happy New Year to you!
            • Stephen L.
              • May 31, 1984
              • 3162
              While you are at this point, you may want to weld the wiper drive arms to the spindles that go thru the cowl. This eliminates some of the "slop" in the wiper movement, as they wipe the windshield......
              • Eugene G.
                • July 31, 1982
                • 62
                Stephen,
                Thank you for the photo. You and Tom were really helpful. Visual was what I needed!
