63 coolant expansion tank strap plating? - NCRS Discussion Boards
  • Daniel T.
    • July 5, 2019
    • 34
    Hi, what is the correct plating for the 63 expansion tank mounting straps? (or are they bare? but then they would rust) I didn't see anything in the judging guide and can't tell if they are bare or maybe dull grey zinc plated? I just vibratory tumbled mine to get rid of the rust and some previous paint which was incorrect.
    Also is there any list of corrections to the judging guide and/or correct finishes for paint and plating of items for a 63?
    thanks- Dan
    62 Corvette 327/340
    63 Corvette SWC 327/300
    67 Corvette Convertible L79
    2006 Corvette Z06
    2011 Corvette Grand Sport Convertible
    also a couple 68 Camaro's
  • Richard G.
    • July 31, 1984
    • 1718
    Re: 63 coolant expansion tank strap plating?
    The straps are cad or zinc plated.
    1963 only tank. Be sure to get the bolt in correctly.
    Please confirm but it may go in from the bottom.
    Rick
    • Daniel T.
      • July 5, 2019
      • 34
      thanks, short strap has the nut welded to it, I'll have to look at the assy manual to see if it shows that detail of which is on top/bottom unless someone else knows for sure? thanks- Dan
      ps- still looking for answer regarding corrections list for current judging manual and/or paint/plating items lists? thanks!
      62 Corvette 327/340
      2006 Corvette Z06
      • Joe R.
        • July 31, 1976
        • 4552
        The short strap is on the top with the nut welded. It would be nearly impossible to attach the long strap if the short strap were on the bottom. It would be especially hard if you had hang-on AC.
        JR
        • Daniel T.
          • July 5, 2019
          • 34
          Joe-thanks for the clarification, as soon as I can get the straps plated I'll be able to put it back together and running again. -Dan
          62 Corvette 327/340
          2006 Corvette Z06
          • Don H.
            Moderator
            • June 16, 2009
            • 2282
            Dan
            there is no corrections addenda nor a paint/finishes list for any of the TIM&JGs. As JGs are revised corrections and more detail is added.
            The 63/64 TIM&JG is in revision now (I think) but publication is still a ways off.
            • Daniel T.
              • July 5, 2019
              • 34
              Originally posted by Don Hooper (50543)
              Dan
              ok, thanks, I've been trying to get up to speed on 63's (just bought mine over the summer), but I've seen several posts on here refering to errors in the judging manual or just on something like these straps missing information on correct finish. I wasn't sure if there was an addendum the judges use to track these additions/errors/updates. Lots of info to keep track of for sure, thank goodness for the forums to ask and learn. thanks! Dan
              62 Corvette 327/340
              2006 Corvette Z06
