Trailing Arm Shims - NCRS Discussion Boards
Trailing Arm Shims
+ More Options
Posts
  • Mark S.
    • April 25, 2019
    • 94
    Trailing Arm Shims
    Does anyone have any thoughts as to whether I should use the slotted stainless shims or the original steel 2 hole shims when installing my trailing arms. Looks more difficult to use the originals and harder to align later but this is my first time doing this. Any help is appreciated.
    Mark
  • Edward J.
    • September 15, 2008
    • 6950
    Re: Trailing Arm Shims
    Mark do your self a favor use the slotted shims. So much easier to align. The rear.
    • Mark S.
      • April 25, 2019
      • 94
      Kinda what I thought. My frame does not have holes for cotter pin but I am guessing when they rest on the inside of frame and the bolts are tight there not falling out..??
      • Leif A.
        • August 31, 1997
        • 3646
        Here's my 2 cents. Buy both the original 2 hole shims and a set of the slotted shims. Take your car to a competent (read old school) alignment shop that is familiar with the IRS of a C2 Corvette. Have them align the rear using the slotted shims. Once they have obtained a correct alignment using an assortment of thickness slotted shims, have them take an inventory of the shims on either side of the trailing arm on both sides. Now, have them remove the slotted shims (keeping track of the thickness on each side), remove the trailing arm bolt and insert the correct 2 hole shims of the same thickness as the slotted ones they removed. Unless you're driving your C2 as a daily driver or hitting pot holes and curbs, you most likely will never have to go through this process again. A good alignment will outlast the typical, minimum driving these old cars get. Again, my opinion, but I like things to be "correct".
        I guess, bottom line, do you want it done the easy way or the correct way...your dime.
        Leif
        • Edward J.
          • 6950
          • James W.
            • December 1, 1990
            • 2669
            Great advice Leif! I will be going though this process in the spring and want it right. Now to find an old school alignment shop. May have to trailer back to my home town in rural Iowa and let the same guy do it that did alignments on my dad's Corvettes.
            James
            • Frank D.
              • December 27, 2007
              • 2703
              I would just go with the slotted shims with the long cotter pins to secure them...
              That's what I did on the 63 Pretty sure Van Steel sells the shim kit and cotter pins.
              And go with STAINLESS STEEL shims if you ever want to get them out easily again.
                • 43259
                Mark
                Mark------
                I would not even consider using anything but the slotted, stainless steel shims. Period. Once installed, the shim types are virtually impossible to discern. However, even if they could be discerned, I'd still use them. This element of originality is minutia to the absolute extreme.
                Shims tucked down into the frame pocket as they should be and tightly fit as they should be will not fall out.
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Correct, my slotted shims did not dislodge even after the poly bushing installed by a previous owner crumbled to ground pepper. If the metal sleeves that the rubber bushing wraps around are installed properly the ends should meet inside the trailing arm for a metal-to-metal connection - so its a snug fitting metal-to-metal assembly from one side of the frame pocket to the other if the shims are snugly installed.
                  I still feel slightly better with the cotter pin as an added safety measure.
                  • Leif A.
                    • August 31, 1997
                    • 3646
                    Mark,
                    One thing you did not mention and is not available from your profile...what year Corvette are we talking about here? It makes a difference as to what's correct for your car.
                    Leif
                    • James W.
                      • December 1, 1990
                      • 2669
                      Leif,
                      My car is a 1965 coupe.
                      James
                      Originally posted by Leif Anderson (29632)
                      Mark,
                      • Mark S.
                        • April 25, 2019
                        • 94
                        I updated my profile. Info is for 69 71, M21. Thanks
                        • Mark S.
                          • April 25, 2019
                          • 94
                          this a great way to do this. Thanks !!!
                          Hopefully my alignment guy will work with me...
