Where does this bolt go? Steering? Or...? - NCRS Discussion Boards
  • Larry M.
    • December 1, 1986
    • 541
    For a 1972, I somehow missed this one when bagging and tagging. I'd removed the steering column, steering gear and clutch cross shaft, and I don't see a home for this. It has a serrated, indented hex head, with traces of thread lock. I really suspect it has to do with the steering linkage, but I can't find it in the AIM or in vendor catalogs.
    All help appreciated; thanks!
    Larry
  • Leif A.
    • August 31, 1997
    • 3657
    Re: Where does this bolt go? Steering? Or...?
    The coupling at the rag joint?
    Leif
    • Larry M.
      • December 1, 1986
      • 541
      Leif,
      Thanks; great suggestion, but no. I'm stumped. I've even checked the tools I was using to see if it fell out of one of them. No luck.
      Larry
      • Owen L.
        • September 30, 1991
        • 895
        I spent the spring and summer of 2020 going through the entire engine compartment, trans, rear suspension, gas tank, etc. - in otherwords, I crawled all underneath and inside my '72 and I don't recall any allen-headed bolt.
        • Larry M.
          • December 1, 1986
          • 541
          Owen,
          You did a thorough search; thanks for your info. That, coupled with my inability to find a home for the bolt, makes me believe it doesn't belong on the car. I'll stop looking.
          Larry
            • 43289
            Originally posted by Larry Maher (10731)
            Owen,
            Larry
            Larry------
            I agree. I know of no application on ANY Corvette for a bolt of this design. Are you sure this bolt is even SAE thread?
            • Larry M.
              • December 1, 1986
              • 541
              Joe,
              Excellent point; thanks. I checked, and found what to me is a contradictory result - a 1/4"-20 nut easily threads onto it, but only a 10mm socket fits the head. What bothers me the most is that I found it on the garage floor directly beneath the steering gear/column coupler area where I had been working. I'll double-check the tools I was using.
              Larry
                • 43289
                Joe,
                Larry
                Larry-----
                There are a few SAE and metric thread sizes that will "interchange".
                • Mark M.
                  • October 21, 2008
                  • 343
                  It could be something related to the column being pulled, but it looks more like a bolt that came with a flat screen wall mount I recently assembled.
                  • James G.
                    • August 22, 2018
                    • 819
                    There are so few allen keyed bolts on a Corvette I do not believe it is from GM.
                    It looks like a bolt from a metal rack or tube framed furniture, I put together some stilts at Christmas which had a similar bolt.
                    James A Groome
                    1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                    1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                    My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                    Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                    • Larry M.
                      • December 1, 1986
                      • 541
                      Yeah, that hex head looked oddball to me, too. I may just hold on to it in case Mark needs another for his flat screen mount.
