Removing Temp Gauge on a 54 - NCRS Discussion Boards
  • John W.
    • December 10, 2020
    • 7
    Hi,
    Do you have to leave the Temp Wire on when removing the temp gauge?
    John
  • Jim L.
    • September 30, 1979
    • 1806
    Re: Removing Temp Gauge on a 54
    I'm not sure what you mean by "Temp Wire". The gauge on a '54 is a mechanical gauge.
    • John W.
      • December 10, 2020
      • 7
      Hi Jim,
      It's the metal "wire" attached to the rear of the gauge. I don't see a way to remove it from the gauge.
      Thanks.
      • John L.
        • January 31, 2005
        • 207
        I think you are referring to what I call the capillary tub that is connected to the brass bulb that is screwed into the head. On the older cars I have taken off with this system I have been able to remove the gauge with the tub and bulb intact including my 54. Even if you are going to send it out for a rebuild I like to keep it all together. Exception might be if the bulb has welded itself to the head with rust and corrosion.
        John
        • Jim L.
          • 1806
          Originally posted by John Webber (67540)
          Hi Jim,
          Thanks.
          You don't want to remove that tube from the gauge. Remove the gauge, the tube, and the bulb (at the engine) as one assembly.
          • Gary H.
            • June 30, 1980
            • 155
            I absolutely agree with Jim, the gauge, tube and bulb are one closed unit. Do not separate.
            FYI, the tube is filled with Ether. If you suspect that your gauge is not giving an accurate reading, like if you have a 180 degree thermostat and your gauge shows a lower temperature, you've probably lost some Ether..
            • John W.
              • December 10, 2020
              • 7
              Thanks for the assistance.
