Parts Tumbler/Vibratory - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1246
    Do any of you own a parts tumbler/vibratory? If so what brand, needs to be big enough to put a drive shaft in.
  • Gary B.
    • February 1, 1997
    • 7080
    Re: Parts Tumbler/Vibratory
    Gary,
    Wow. Driveshaft size is big!
    Gary
    • David H.
      • June 30, 2001
      • 1567
      Gary
      What restoration does this driveshaft need?
      What about media blasting?
      Dave
      • Gary J.
        • April 1, 1980
        • 1246
        • Gary J.
          • April 1, 1980
          • 1246
          If you glass bead them and then tumble them it puts a nice finish on them. Can be done to other things.
          • Tom L.
            • October 17, 2006
            • 1439
            Have never tried this but a little back yard engineering might get you what you need.
            Large DIY Vibratory Tumbler : This instructable is a guide on how to design a vibratory tumbler. I couldn´t find a lot of information on how to build one, so I experimented and here are my findings that hopefully help you. This is somewhat of a advanced build, so I keep this sim…
            Tons of other links and video's out there, have fun!
              • 11698
              Check with your local engine/machine shop about shot blasting, NOT bead/sand blasting.
              It works great, and the box they use is likely large enough.
              • Harry S.
                • July 31, 2002
                • 5346
                Whenever you touch a driveshaft, have it balanced. Install new U-joints with the slip yoke and have it balanced as a unit. When you take it apart to install it, mark it with crayon so it go back in the same way.
                It arrived in St. Louis as a balanced assembly.
                • Gary B.
                  • February 1, 1997
                  • 7080
                  • David H.
                    • June 30, 2001
                    • 1567
                    Originally posted by Gary Beaupre (28818)
                    ... It’s the first time I’ve seen welds that are close to mine in quality. ...
                    I see welds close to mine in quality all the time .....
                    Dave
                    • Gary J.
                      • April 1, 1980
                      • 1246
                      Gary,
                      Gary
                      I measured the drive shaft and it measured 31 inches, so not that big.
                      • Gary B.
                        • February 1, 1997
                        • 7080
