63 327/300hp carb return spring bracket - NCRS Discussion Boards
  • Daniel T.
    • July 5, 2019
    • 34
    What is the correct finish for the carb return spring bracket that mounts on the front two bolts of the intake? I don't see anything in the judging manual if it was on before the motor/intake was painted or put on after? Reproductions seem to be black or either bare steel or plated I can't tell. thanks!
    62 Corvette 327/340
    63 Corvette SWC 327/300
    67 Corvette Convertible L79
    2006 Corvette Z06
    2011 Corvette Grand Sport Convertible
    also a couple 68 Camaro's
  • James W.
    • December 1, 1990
    • 2669
    Re: 63 327/300hp carb return spring bracket
    Daniel,
    The bracket was installed prior to the engine being painted. It was most likely bare metal and would be painted orange with limited paint coverage on the inside or back of of the bracket when view from the driver's side of the engine.
    James
    • Harry S.
      • July 31, 2002
      • 5333
      Daniel, It is steel, therefore magnetic. If you have a stainless one, look for an original.
      • Daniel T.
        • July 5, 2019
        • 34
        Thanks for the replies, it is steel not stainless but i couldn’t tell what the correct finish was, then seeing two finishes on the repro parts had me lost more! Awesome. Thanks! Dan
        62 Corvette 327/340
        2006 Corvette Z06
